Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Quick Guide says to see 'on-screen User's Guide'
I can't find that User's Guide on-line! I want to scan color photos to my computer AND a flash drive. HELP. Darlene
    President:
  • 1,901 Answers
Here is a link to your printer's user guide.
http://files.support.epson.com/htmldocs/rx680_/rx680_ug/index.html
You can right click on it and save it to your Favorites for future use.
Posted on Jan 13, 2009
  • Wayne Mineard
    Wayne Mineard Jan 13, 2009
    Be patient. It may take a while to load depending on your system and ISP.
I have a Dell P703 and want to scan photos to a flash drive but the printer will not, it keeps asking for a memory card when I insert a memory care I receive the message "Please insert memory...
I'm not so sure that this printer supports scanning photos to a flash drive. If you take a look at the user guide, the only advice given about scanning problems is that they want you to make sure the printer is attached to your computer properly.
This leads me to believe that what you are trying to do is not supported. The USB por that is available is most likely used to plug in a camera directly so that pictures can be copied from it and printed.
http://support.dell.com/support/edocs/systems/P703w/en/UG/troubles.htm#wp1180022
Jun 13, 2011 | Dell P703w Printer
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
Apr 08, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I need to know how to transfer a photo in my LG Quantum phone to my computer.
Hello, you can download the LG Quantum user guide from here: http://www.userguidemanual.com/lg-quantum-c900-user-manual-quick-start-guide-att/ It will tell you how to transfer a photo to your computer.
Mar 05, 2011 | Cell Phones
Picture looked 3d now tv wont come on. red lite flashes 6 times.
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts down
  • TV Chirps
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Sony KP-51WS510 51" Rear Projection...
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
My whole screen is arched and the red blue and green are not lining up right, u see 3 versions of every picture. what could this be? can i fix it myself?
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
Green and red lines
  • Screen looks 3D
0667c5f.pngSOLUTION
Mar 19, 2009 | Sony KP-57HW40 57" Rear Projection...
Color convergence drops on left side
  • Screen looks 3D
Mar 13, 2009 | JVC AV-48WP30 48" Rear Projection...
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
What is an on screen user guide?
The On screen User Guide is usually a PDF or HTML file that you bring up on your monitor (screen) instead of a hard copy booklet.
Here is a link for your user guide:
PS. You can right click on this link and add it to your favorites (bookmarks if using FireFox).
Jan 13, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
