I am trying to connect anew printer using a BT wireless Home Hum
SOURCE: Unable to connect wirelessly to my Samsung CLP 315W
configure the setting manually by putting the printers IP address....install the driver first
verify your printers support site and download the updated/new drivers and patches need to install.
link for Drivers and manual:
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=colorlaserprinters&model_nm=CLP-315W&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=06010200&disp_nm=CLP-315W&model_cd=CLP-315W/XAA&menu=download
SOURCE: Connecting printer using usb causes "blue screen of death".
Have you tried reinstalling the printer drivers?
SOURCE: Epson TX800FW
u have to tourn on file and printer sharing on yours printer, open printer and faxes find yuor printer, right click it and then click propetys inn the properys meny click sharing then turn on file and printer sharing.
SOURCE: Cannot connect printer to a home network through BT Homehub 2
Hi, I understand your problem.For that first go ahead and insert the cd..then go to my computer>>right click on the cd>>then click on explore>>util>>ccc>>uninstall l3..
it will give you a black dos screen then let it be complete..
then restart the computer..click on start>>run>>type cmd(if its a xp system)..then ping the ip adress..if its pinging then good or else go ahead and run the wireless setup wizard..it will be under the printer's setup menu ..and u will be able to find that in the printer itself.then go to wireless menu..and you will be able to find that..after getting the new ip address just go ahead ping it..it will work. then install the printer..and u will be use it perfactly..best of luck..
SOURCE: printer offline on wireless home network
first make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
