Advertised specifications does not include a tuner. Specifically, the 'INPUT TERMINALS" does not include an RF/ANT/CABLE IN connector. Normally, the ANT connector would look something like below image for US standards.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Hi and welcome to FixYa,
You can't post conmments that contain an email address.
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Don't throw it away just yet. It's still under warranty so returning it would be far better than throwing it away ;)
As you can tune the cable channels OK, I suspect there is a problem with the reception from the antenna and the signal strength is too low. Please can you answer the following simple questions so that I can help you to solve this problem
1. What antenna are you using - indoor/rabbit ears or outdoor/roof antenna? 2. Do you have a good reception on another TV connected to the same antenna ?
If you are using an indoor antenna, try moving the TV to another location to see if you can get a better reception.
Please let me know the answers to the above questions. I will then be able to assist you further.
You either have a malfunctioning LCD controller(T-con) or the panel itself is faulty. The T-con is very inesxpensive and easy to replace but the panel is gonna cost you nearly as much as a new tv. Let me know if you want to give the t-con a shot so that I can guide you to fix it.
Good day sir/maam, the trouble is caused (possibly) by the failure of the IF amplifier system of your TV, it is usually sets of transistors, or an IC that controls the gain of your TV. Have your service repair man check the section fro the tuner stage to the IF stages. chances are the IC is not functioning properly. Hope this helps.
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
You have to conected it to the line out audio. In the back of your tv will be says "Audio Out" conect it with the red and white cable to your rca seround system and press "Aux" button on it.
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
