Question about Dell Latitude D600 Notebook
I have a Dell Latitude D600 laptop whose USB port is being used to charge the battery in an iPod Shuffle music player. The laptop shuts down after about thirty minutes of inactivity, preventing the iPod from receiving a full charge lasting four hours. Is there a way to override this automatic shutdown so the laptop can be used to fully charge the iPod's battery?
    Problem Solver:
  • 8 Answers
As i recall shuffles do not have a power adapter supplied.
You need to adjust the power options in the control panel
Dobule click power options
select the power scheme drop down and select ALWAYS ON.
click apply and ok.
Should sort it for you
Posted on Jan 11, 2009
  • Dell Master
  • 32,281 Answers
You can use a powered USB hub to charge your iPod, MP3 player etc. without connecting to a laptop's computer USB port.
Just connect the mains adapter to the USB hub and then plug your iPod into the hub for as long as you need.
You can also use this hub for your computer/laptop when you need extra USB ports..
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here:
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries:
May 10, 2011 | Apple iPod shuffle MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i download songs to my iPod model no.A1204 EMC no. 2125? and how to charge it?
As with all iPods, you must use Apple's iTunes application to sync your music with your iPod Shuffle.
You'll need to install the latest iTunes by downloading it from Apple click here> and then installing it. You install iTunes like any other downloaded program by double-clicking on the resulting icon after iTunes has successfully downloaded.
Follow the on-screen directions to install iTunes.
Once iTunes is installed, start up iTunes and have it search your computer for music for it to manage for you. While that is going on, plug the white USB cable that came with your iPod into your iPod Shuffle and into one of the USB ports on your computer. This will trigger iTunes to recognize your iPod Shuffle and ask you whether you want to set it up with this computer.
Follow the on-screen prompts to sync your iPod Shuffle with your computer.
To charge your iPod Shuffle, just keep it plugged in to your computer using the supplied white USB cable. Keep the cable connected until the battery indicator on the ipod Shuffle shows that the battery is full.
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    How to use an ipod shuffle charge
    Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
    • iPod shuffle (1st generation) - iPod Software version 1.1.5
    • iPod shuffle (2nd generation) - iPod Software version 1.0.4
    download here
    then install..
    follow these instructions..
    Using iPod Reset Utility
    1. Quit all running applications on your computer.
    2. Open iPod Reset Utility.
    3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
    4. Click the Reset button.
    5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
    6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
    Jun 05, 2010 | Apple iPod shuffle MP3 Player
    You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
    .DELL LATITUDE D600 Drivers Download Link
    Feb 05, 2010 | Dell Latitude D600 Notebook
    Override laptop automatic shutdown after inactivity
    Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
    Please rate this solution accordingly. Thanks for using
    Jan 10, 2009 | Dell Latitude D600 Notebook
    Override Dell Latitude D600 laptop automatically shutting down
    yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
    Turn of the display> change to four hours
    Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
    I hope this helps
    Dell Latitude D600 Notebook Logo
    224 people viewed this question
    Alun Cox
