Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer making clanking noise
I have a dryer that's about 15 years old and just recently it started making a clanking noice (almost sounds like when there is a pair of jeans with a zipper hitting against the sides) and sometimes seems to keep turning when I open the door.
  • frankjasie Jan 10, 2009
    I have the same problem. I thought it might be a drum strap fraying and slapping against the cabinet
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Posted on Jul 03, 2010
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
Maytag my dryer just makes a humming noise without spinning. then i got it to start spinning again. this is a new problem never had it before although the dryer is 15 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
We have a Maytag gas dryer that is probably 15 to 20 years old. It still works fine, but it makes a noise when it fist starts up. Sort of like a grinding sound .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 27, 2010 | Maytag Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
My Maytag dryer is 14 years old. Now it makes a
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
271 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
