Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Lens will not retract
Upon either power-up or power-down, lens will fully retract, but then immediately pop back out, fully, and end in E18 error code.
I have tools to take it apart fully to blow out lens mechanism, but is that likely to solve problem?
  • Robert Sonderegger
    Robert Sonderegger Jan 11, 2009
    I tried every single fix, slowly and carefully. None worked. At the end, I must have squeezed the camera too hard, because suddenly nothing works anymore. Nothing happens when powering up.
    I don't blame this site, just to say that I must be part of the 54% where their methods did not work.
    Robert
  • Canon Master
  • 4,738 Answers
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 11, 2009
  • CameraR
    CameraR Jan 11, 2009
    Here's some things to try to get your camera running again.
    http://camerarepair.blogspot.com/2007/11...
    Suspect the battery terminals could have been bent downward from tapping the camera during Fix 6. Also check the pin switch on the flash door, and the other on the battery door to make sure that they're closing when the doors are closed.
How do I fix "lens error" problem described below?
usually caused by particles in the lens advance and retraction mechanism.may need cleaning by expert.but first try to GENTLY pull the advanced lense out up to fully out position.note the word GENTLY,otherwise the camera will be ruined.
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
E18 error message
I found this on cnet.com Hope it helps.
E18 quick fix
I'm sure that every1 looking at this right now would love to be able to do a quick fix for the dreaded E18 error. Well, I have fixed mine several time in less time that it takes to take a picture. So here it is: This error occurs when the lens is "stuck" or not extending "straight". The error can happen in 3 ways: either when the lens wont "come out", or "comes out" and then retracts, or does not retract at all. Mine did all of these at one stage or another.
1) If the lens doesn't extend at all or it extends, but then retracts again, do as follow:
Turn the camera off. Place the camera on it's back with the lens facing up and have a look at the "spacing" between the lens and the lens housing. You'll probably notice that the gap is NOT EVEN all the way around. To fix this, simply -VERY GENTLY- press down on the side where the gap is the biggest. You will hear a "click" as it pops back in place. Try powering it back on.
2) If the lens is extended all the time and won't retract at all, do as follow:
Turn the camera off. Take the camera in one hand and with the other gently, in turn, take the two part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will once again hear a little "click" as it pops back in place. Power the camera on.
This has worked for me many times and it seems to happen when the camera has been carried around and possible had a little knock. I hope this is of help to someone else.
Jan 05, 2011 | Canon PowerShot A95 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera gives E18 error!!!
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Oct 03, 2009 | Canon PowerShot A410 Digital Camera
E18 error on powershot canon
Hello there,
Sep 27, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
My canon 550 has a len error an saying E18!
Hello there,
Aug 29, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Lens stays out
E18 is lens error. When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Jan 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
E 18 problem
Hello there,
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
