Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Uniden wireless AS1002-MG is showing error as handset is out of range
coolcat_12
  • 259 Answers
SOURCE: my handset reads "out of range" but it is sitting on the base.
It could be faulty phones or try replacing the batteries
Posted on Jan 10, 2009
micromaster
  • 3614 Answers
SOURCE: No dial tone on handset; cannot make or receive calls
hi there,
better do registering again the phone to the base station. you ma consult your user manual on how to register again the handset.
hope this initial info helps.
Posted on Apr 16, 2009
  • 24 Answers
SOURCE: my uniden dect 6.0 model# 2088 base doesn't
disconnect the battry and the phone like from the base and the phone(s) and them put them back together and see if it works.
Posted on Mar 12, 2010
SOURCE: i have a uniden tru 8865, can't de register
Hold End and # buttons for a few seconds
Posted on Jul 03, 2010
  • 1417 Answers
SOURCE: existing uniden 3-station dect3380; all handsets
Put of the phone for some time allow it to relax and get it memory then put it on after some time.If the problem remain then you will have to contact the service provider through another phone or visit there office. i.e the phone sensor will need to be reprogram from there office.
thank you thnaks for using fixya.
Posted on Oct 18, 2010
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
My uniden phone says - out of range
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Every phone has handset
All four phones showed "Out of Range" I unpluged the main phone - the one with the telephone hook up. I left it unpluged for a few minutes, plugged it in and IT WORKED> Thanks for your interest in helping me.
JJS
Nov 19, 2009 | Uniden 2.4 GHz Cordless Phone System
Handset out of range
Hello Dmark,
2.4 Ghz is a fairly common household frequency...
Conflict with other systems COULD ALSO
be your problem...
ASSUMING you have had this system
same place, same usage... and have added
NOTHING in your house
(like wireless Cameras, DOT, ECHO, ALEXA, etc.).
There comes a point in the owners of a
DCT758-4 Uniden system's life...
When it is time to check the base battery contacts...
BATTERY charge indicator... and general system
performance;... (battery indicator).
Only the MAIN base is the RADIO BASE...
Depending on battery condition...
You might want to TRY moving your weaker
hand sets around to more appropriate locations...
Failing that...
YOUR BATTERIES ...
(I have shown below) are widely available
from places like eBay and AMAZON...
I am showing AMAZON for informational purposes.
FREE SHIPPING figures PROMINENTLY in my
BATTERY BUYING... So I use TRUSTED SELLERS
on eBay...
(USA: $3 - $5 each (Battery cost for your phone) .
Happy hunting...
Hay un problema muy pequen(y)o.. (not English)
Uniden DCT758 3 DCT Cordless Phone Manual Del Usuario Page 6
May 12, 2017 | Uniden DCT758-4 Phone
hi there,
Apr 16, 2009 | Uniden Lands Phones
I have a Uniden wireless phone 5.8 that is locked
Put on some reading glasses because I know i can't see everything on the phone myself. It should show a icon of a lock. press that button for a few seconds and unlock should appear or the lock words should go away, Good Luck. Do you have the book that came with? if you do it will tell you also be sure to have those reading glasses because it makes life so much easier. really it opens up a whole new world.! Good Luck!!
Feb 08, 2009 | Uniden 5.8GHz Dual Cordless Phone
Ou t of range
i just fixed mine! hold # and * together let go and do it again, it will reset.. you will be able to make calls again
Dec 29, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
122 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
