Question about Philips Magnavox DVD/VCR Dual Player
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
  • jpactech May 11, 2010
    can you take a photo of the rear back and uplosd it I need to see the back of that unit then I will tells you what you need to do. also what kind of tv is it take a photo of the tv rear where cable hooked up does it have yell,white,and red...pins? check and see what it says.input or output..let me know ...
    Master:
  • 416 Answers
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Posted on Jan 10, 2009
  • Grigory Zyryanov Jan 10, 2009
    I am always ready to help, so if you need more details let me know
    Good Luck
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Hooking my DVD player up to my HD converter
connect as follows,,,
converter-->VCR-->TV
DVD-->VCR-->TV
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hi Karen, I think you are having connection issues. Can you provide specific details of the connections? Thanks, Mike
Nov 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Philips Magnavox DVD/VCR Dual Player Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
