Panasonic dmr-ez49 disc reads unsupported port and is stuck on recording
Shuttle83
  • 1139 Answers
SOURCE: Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 16, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
SOURCE: DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
Posted on Jan 01, 2010
Demonic-2011
  • 508 Answers
SOURCE: I HAVE A PANASONIC DMR
The 'No Read' error is a classic case of a failed laser (and/or DVD drive). In many Panasonic DVD devices (recorders, players and some Blu-Ray models) the laser is part of a traverse unit or 'assembly' (a block with laser and spindle motor in one). With this unit, unless you are tech. savvy and are aware of the likely cost(s) of replacement part(s) for this type of product, you can go ahead and order from Panasonic directly - subject to shipping and tax (assuming the part is available) - this could be expensive, and you would also need the right equipment/tools and experience to do this (it is much easier to simply replace the whole DVD drive itself in the unit - just note the original drive number and connection type before seeking a new one, after that - should be a straightforward fit, save on labour costs...) - these drives are not exactly easy to repair at individual component level; hence why in most cases the whole drive is replaced when part of it fails (not impossible to replace either!).
If you aren't familiar with this sort of thing, your next best bet is to submit the recorder to an authorised Panasonic service centre, obtain a (reasonable) quote on likely repair/part(s) cost(s), along with a second opinion, then you can make a firm decision on that basis. Up to you whether you pursue it further or not. The DMR-EZ28 is not as old as the DMR-ES15 and is more reliable in general. Assuming this can be repaired, it could be very expensive, so keep that in mind, but you won't know for sure unless you get a quote from a workshop. It may also take several weeks before repair (if possible) is completed.
If all else fails, or it is probably going to be too expensive/uneconomical to fix, or you cannot get a replacement DVD drive anywhere for this model, then consider a new one - but ONLY as a last resort. The cost of replacing a disc drive in your existing unit vs. the cost of a brand new machine could be significant.
Not the best news, but certainly worth investigating - if you want to do so.
Posted on Mar 24, 2011
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Hello, Dustin / unsupported discs issue
Hi Brad
Before you attempt to purchase a new lens or a new unit, i would suggest that you buy a "Len Cleaner Disc" to clean your lens, if that doesn't help then you should either repair or buy a new lens.
To repair or install a new lens, you will need a service manual(Let me know if you need one.) Then you can do it yourself.
Please also remember that if you attempt to open or repair the player in anyway, it will void your warranty so i think you should take it to Panasonic and have the unit replaced or refunded.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse (BearWeb)
Jul 03, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Panasonic DMR-ES30V
I have three Panasonic DVD recorder/Vhs combos and I get the same problem from time to time...it may be the disks you are using.  Mine absolutely hate Sony disks.  I have the best luck with TDK or Maxell.  You also must clean your unit frequently, if you do alot of recording.  I use my units daily.
Hope this helps
Oct 31, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
