Question about Posiflex Office Equipment & Supplies
For the Posiflex printer series PP8000 the cutter blade is getting jammed how do i get it fixed
SOURCE: how can we set margin in posiflex pp8000 partial
a beep sound when i connected the posiflex pp8000 v3.01printer to my pc and also papper out inticator is glowing. what i do to solve the problem ?
Posted on May 07, 2011
  • 32 Answers
SOURCE: Auto Cutter
Part # ACC-230kit
or send in for service 95.00 flat rate repair.
Agson 856-751-9048
Posted on Feb 12, 2008
  • 89 Answers
SOURCE: How do you install a Posiflex PP8000 printer on
posiflex pp8000 does not have a device driver for windows 7. you can check this for reference.
Posted on Mar 12, 2010
multilinkent
  • 739 Answers
SOURCE: Need the cut of string
hi. did you mean need hardware to buy, or can u explane in detail problem yr have.
TQ
Posted on Aug 12, 2011
  • 1833 Answers
SOURCE: POSIFLEX PP8000 CUT OFF STRING
The code is 0E.
Posted on Aug 13, 2011
Cutter on speedylock
Servicing the Timing is NOT a home fix
Mar 08, 2014 | White Sewing Speedylock 1600 Mechanical...
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
How can we set margin in posiflex pp8000 partial cut v3.01
Nov 24, 2009 | Posiflex PP7000 Printer
The blades on my Braun complete 8975 are not sharp anymore.
Braun complete 8975 replacement foil and cutter blades is Braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 8975 360 Complete Men's Shaver...
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
52 people viewed this question
Top Posiflex Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Posiflex Office Equipment and Supply Expert? Answer questions, earn points and help others
