Question about Music
WIRE DIAGRM GEMINI SOUND MIXER MX 3301 - Music
2 Suggested Answers
  • 1212 Answers
SOURCE: HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Posted on Apr 27, 2012
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:
Solution 1:
1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.
2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.
Solution 2:
1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
Jul 19, 2012 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
Help my gemini cdmp-6000 service manual
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 03, 2011 | Gemini Sound Products Gemini Cdmp-6000...
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
Gemini FX 7000 DSP effects no longer working, aparently a blown i.c, but which one?
A lot of the effects chips run off of the +5 volt or +3.3 volt power source while a lot of the audio is off +/-12 or 15 volts. Sometimes loss of the +5 causes loss of the effects. Check that before assuming a chip is gone.
Jul 21, 2011 | Gemini Sound Products Gemini FX7000 10...
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
My cdmp-6000 always hangs and resets.... what causes it? and what maybe the possible solution?
I can give you some questions to verify possible problems:
1. Is the mixer, and ALL connected equipment powered from the SAME receptacle? If not, ground bounce can be causing damaging transients. This OFTEN requires running power back from where amps are to the mixer using an extension cord.
2. Are ALL audio interconnectsusing balanced lines where possible?
3. Is humidity 40% or greater? If not, possible static discharges from rugs, clothes, etc. may be causing transients that reset the unit.
4. Are stage lighting equipment run from a separate source to avoid transients from dimmers and switching?
5. Is the power all have three wire cords and the building have grounded receptacles?
If your system satisfies all these the next step I would suggest is a high quality power conditioner.
May 07, 2011 | Gemini Sound Products Gemini Cdmp-6000...
Music Logo
37 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
