Question about Verge VGA300M Car Audio Amplifier
Verge VGA300M Speaker terminals
I just bought a used Verge mono amp off of ebay, before I wire it up, I wanted to ask this question. On the amp there are 2 positive terminals side by side and 2 negative terminals side by side, when I go to wire my subs, do I use both the positive terminals together or separately, I have never owned a mono amp before so I'm not sure about the speaker connections on the amp.
  • 156 Answers
Mono amps often have two sets of speaker outputs; this is just to simplify multi-speaker connections. The two positive and negative terminals are connected together internally, so they're effectively the same as one terminal. There's no difference between connecting both subs to the same positive and negative terminals, or using different terminals for each sub; electrically they'll all be connected together either way.
Posted on Jun 07, 2007
How do i wire my kicker dcvr122 up to a 4 ohm amp
I am going to assume the 2 speakers in the sub are each 4 ohm loads, and are wired together in parallel, creating a 2 ohm load. And your amp pushes 800W at a 2 ohm load. And actually goes down to 1 ohm/1100W. Anyway...
Seems you want to lessen the wattage output of the amp by making a 4 ohm load. To do that, you need to wire the both 2 ohm speakers in SERIES.
In general wiring principles, to wire in SERIES, take the POS terminal from the amp and wire to the POS terminal of first speaker. Take the NEG terminal from the amp and wire to the 2nd speakers' NEG terminal. Then place a "jumper" piece of speaker wire to connect 1st speakers' NEG terminal to 2nd speakers' POS terminal. Now you have a 4 ohm load, and will be pushing 450W from your amp.
This way the load will now be 4 ohms.
Jan 08, 2013 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
Jl audio g1700
this is a mono block amplifier ,both positives are the same inside the amp and both negatives are the same ,there is 4 terminals to make it easier to wire 2 speakers . Use either positive and either negative ,with this speaker ,inside the box you can wire both positives together and negatives together (parrallel) this should be 3 ohms and the amp should run smoothly ,maybe a little warm but that amp can take it .
May 07, 2012 | Jl Audio G1700 Car Amp
I have a carver M-2050i amp that I am putting in my truck. Want to hook it up mono to one of my 15" subs. Looking how to wire it for mono. do I use the L - and R - or L + and R+ or something else. I have...
to wire up your sub in mono bridged mode it's either L+ and R- or L- and R+ it should say this on the body of the amp in front of the speaker terminals. If it does'nt i would check to see if your amp is bridgeable if it is not i would advise against it as this could damage the amp.Hope this is helpful
Oct 26, 2009 | Audio Players & Recorders
KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Jan 13, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
Oct 21, 2008 | Verge VGA300M Car Audio Amplifier
Alpine 3523 no instructions or wiring
I know this is a little late but I have one and the hookup is very easy, On the right side of the amp there is a six pin plug. Above it it says BATT REMOTE GND. The two pins below BATT are the battery (V+). The pin below REMOTE is the (V+) switched turn on. The two pins below GND are the ground. The rest is simple. Two RCA inputs. The switch to select MONO(R), STEREO, or MONO(L) works as explained. If you want stereo, put the switch in the middle and supply two inputs and two speakers. The MONO(R) and MONO(L) are to select a single input that will supply a single (bridged) output. Connect two speakers and they will supply the same source or connect one speaker to the outer speaker terminals for higher power output. The variable or fixed switch just bypasses the GAIN CONTROL knobs(used for Alpine's 8 pin DIN plug on unit, for older EQ's and head units.
Jan 15, 2008 | Car Audio & Video
How to install this amp properly?
The amp is a mono amp with only one output channel so it cannot be bridged. You'll use one positive and one negative per speaker. The positive speaker terminals are connected together and the negative speaker terminals are connected together so it doesn't matter which you use for the individual speakers.
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
No sound
you may have a blown speaker...many cd decks will shut off their audio circuits when a speaker is blown to protect from shorting out. Go to the back of the deck and try disconnecting speakers one by one. You will have to turn the deck off and back on each time. Hope this helps!
Jul 16, 2007 | Verge VGA300M Car Audio Amplifier
Verge VGA300M Car Audio Amplifier Logo
275 people viewed this question
Top Verge Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Verge Car Audio and Video Expert? Answer questions, earn points and help others
