Question about Magic Chef CTB1521 Top Freezer Refrigerator
Where is drip pan in magic chef frige freezer
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Magic Chef fridge, freezer compartment
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
oldTech2332
  • 2341 Answers
SOURCE: magic chef model number CSB2323AR
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Posted on Aug 07, 2011
I have a magic chef French door refrigerator. Water under the freezer becomes ice and when this melts water seeps onto the floor. Sometimes enough water to completely soak a couple of towels
Lower the setting to your FREEZER this may be defrosting too often and the drip pan is over filling, or stop leaving the doors open too long .
Oct 04, 2014 | Magic Chef Refrigerators
Zel 67W Zanussi refridgerator
new frige smell? not rotten food. something to do with motor maybe stale water in pan. how do i clean it. i see some screws do i need to unscrew something to get to pan. where can i put bleach or clorox? have had for 1 day and the odor is annoying. like a plastic smell. don't think its wiring shorting or anything like that but who knows. landlord replaced my leaking frige with this used one. magic chef model# mcbr1020w
hy60yhur r1340 LBP
huayi compressor 1005057074
Aug 15, 2013 | Electrolux Refrigerators
Drip pan seems stuck. Misplaced misaligned
Why do you say that? whats the fridge doing?
Aug 14, 2013 | Magic Chef CTB2125 Top Freezer...
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Why does my magic chef refrigerator leak water on the floor
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Jun 30, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Magic Chef CTB1521 Top Freezer Refrigerator Logo
32 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
