Question about Xerox XG-91D 19" LCD Monitor
Screen has an overall PINK-ish tone to it.
I've attempted re-calibration and RESET the monitor.  Any ideas on what could be wrong with the machine.  Does anyone have a PDF manual with troubleshooting guides on this product.  The monitor was donated to me by an office that lost the original manual.  Many thanks. Tad
    Problem Solver:
  • 6 Answers
This a indication of your back lamps are bad
Posted on Jan 12, 2009
How do I adjust the color on monitor?
Instructions
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more : http://www.ehow.com/how_8446307_fix-color-pink-hue-everywhere.html
GOOD LUCK.
May 11, 2014 | Acer V193w LCD Monitor
Why does my new ASUS VE278H have a overall pink screen color that won't go away with color adjustments?
You have a faulty/damaged screen but you might also check your video colour settings in windows/linux whatever OS you use
May 06, 2014 | ASUS VE278H 27" LED LCD Monitor - 16:9 - 2...
Mac laptop sreen has pink color. Why???
idea of screen calibration is that all screens are different in several aspects, color expression being one of them. If the screen is severely tinted pink, that might be a problem,
Nov 30, 2012 | Apple Mac Pro One 2.8GHz Quad-Core Intel...
Whole screen pink and edges distorted green its on my dell insiron 6400 laptop
check the connctions on your monitor. I had this problem on my monitor for 2 months and it started shortly after I cleaned my desk so I thought maybe I had accidentally pressed a button. I found out later that a wobbly connection to the monitor gave faulty connection info to the screen so I just touched it today and it went magically white. Please try it before attempting anything else!
May 13, 2010 | ASUS VW222U Monitor
Pink Screen
Probably the color temperature setting or some other color settings - since you didn't specify your monitor's brand and model, it's hard to guess.
Anyway, most monitors have a "Reset to factory defaults" feature - you may want to make use of this...
Mar 10, 2010 | Dell Computers & Internet
Unable to Calibrate: Dell E153FPT
CHECK THE DRIVERS OF THE MONITOR, TRY TO UPDATE THE DRIVES
RESETING THE REFRESH RATE LOWER THAN IT IS NOW
IS THE RESET BUTTON THAT WILL SET THE MONITOR BACK THE THE MANUFACTURE ORIGNAL SETTING,
THAT MITE AN OPTION ON THE COMPUTER ITSELF, SHORTING OUT THE BOIS ON THE MOTHERBOARD BUT WHEN YOU DO THAT YOU CLEAR EVERYTHING ELSE LIKE HD,KB,MOUSE, CDROD,DVD,FLOPPIES, MONITOR SETTING,
ROD
Feb 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Lcd display mainly just white
Hi...Brye,
Well... you've fixed the inverter problems, but another problems has pop-up...It's seems you probably burnt out the chipset that contains the bios. That's why the screen turned white... cuz no information in the bios. You'll need to updated the bios or just replaced a new AD Board. Have fun...Good lucks!
Sep 14, 2008 | Computers & Internet
Xerox XG-91D 19" LCD Monitor Logo
147 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
