Question about Cobra 2000 Gtl Cb Radio Manual Service Manual Cd 83pg
Fix for a cobra 2000 gtl recieve
No recieve
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Go to cbtricks
Posted on Feb 14, 2015
Mechanic688
  • 204 Answers
SOURCE: cobra 200 gtl dx clarifier clip
Egor, hi. I'm sure there is a mod probably only known by the repair centers. I have converted and tuned the 200, but in case you don't know, the radio is full of surface mount components. They look like specks of pepper to the naked eye, and so it takes a tech with years of soldering experience to do any modding without destroying what their working on. Those radios are not a friendly radio for experimenting. I looked thru my papers that Cobra tech support sent me for converting, tuning, and other misc. mods but that info was not included. It is a nice radio when set up properly, so don't mess it up by experimenting.(just my opinion) Hope this helps,,and good luck, Mechanic
Posted on Feb 22, 2008
  • 9 Answers
SOURCE: cobra 148 gtl channel mods
contact me i can mod your radio for 65.00
Posted on Dec 06, 2008
  • 32 Answers
SOURCE: cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Posted on Feb 02, 2009
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
  • 773 Answers
SOURCE: Cobra 1000 GTL by Dynascan
This is a complicated modification. I have never done it to a 1000 GTL, but its done basically the same in all radio's.
I don't recommend doing it, especially since I am not 100% sure on how exactly to do it. I have never been in a 1000 gtl. If I had one in front of me I could tell you for sure how to do it.
If the reason for Variable power is a linear, just a swing kit in for the dead key you need, most likely 2 watts, and leave it.
Here is how to do a variable power mod. this is assuming the swing mod is done the same to this as a cobra 25/29 or uniden 68/76 etc.
If you would like to try it, here it is.
You get a TIP31 transistor, Radioshack has them.
Where you put the swing mod in the radio, which is a cap and a resistor, you put the TIP31 and cap. A 47uf cap works fine.
With the resistor facing you, and the tab in the back away, solder the cap to the transistor. the leg with the black stripe goes on the right most leg. then the other goes to the center leg of the transistor.
Solder a wire on the left most leg, long enough to reach the front of the radio. Now solder the 2 legs that don't have the wire on it, in the place where you would put the swing kit, with the black stripe on the cap facing the back of the radio usually.
Remove the wires from the RF gain and solder them together.
Now solder the wire from the transistor to the center tab.
Remove VR6 and solder a wire from the top tag of the RF gain to the top connection of VR6 that you removed.
Then connect a wire from the bottom tag to a ground point. The side of a tuning can works fine.
Take a piece of shrink tube and put it over the TIP31 so it does not ground against the heat sink, that would be bad.
This is done basically the same in all cb radio's.
Posted on May 03, 2009
How to fix cobra 1000 gtl Powers up,meters stuck, no rx just static, All lights work, A mic will Key the on the air light,
have you checked the voltages inside the radio?If you have to much or to little it will not work properly.
Jan 19, 2014 | Cobra 2000 Gtl / 1000 Rf Pwr / Signal...
Have a cobra 2000 gtl has no output on am but has recieve? works fine on ssb. final and driver replaced.
could be a blown tx diode in am.you would be better off taking it to a tech and let him fix it then to mess with it and have something else go wrong.
Dec 24, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Reset on the back of cobra gtl 2000 cb radio
the reset button is used to reset the cpu when doing mods.try replacing with momentary press switch.
good luck
ken
Apr 04, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Superstar DM 452 echo mic wiring for a 4 pin cobra 2000 gtl ?
Note: The pin numbers are marked on the end of plug.....#1.shield, #2.white, #3.red, #4.black.....that means #1.shield, #2.audio, #3.transmit, #4.recieve..........hope this helps.........
Feb 16, 2010 | Cobra Radio Communications
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000 Gtl Cb Radio Manual Service Manual Cd 83pg Logo
152 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
