Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
Reset Procedure?
By jason_o on Jan 10, 2009
Can anyone post the reset procedure for the B-60 here? Can't seem to find it and don't want to wait for customer service to respond. thanks.
Same Problem
Apr 10, 2009
-   Had the same problem with my B60 right out of the box. The brewer never sucked in any water. Tried the reset twice and still didn't work. The Keurig technician called and I went through the reset process with her and now it works. -   Guest
Feb 01, 2009
-   Sorry the solution buddy is not in the manual.... You have to call the damn company for a reset. Sorry I am having the same problem and I am going to get the machine and put it where the sun doesn't shine...Just kidding... I have to wait until Monday to speak to a live person :)
-   Guest
Best Solution
posted on Jan 10, 2009
Very Helpful)
jyackle5
Rank: Guru
Rating: 90%, 1304 votes
Can not find the reset but here is the manual if you do not have.
http://www.keurig.com/help/B70_Use_Care_Guide_Spreads.pdf
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 19, 2009
Helpful)
merv37
Rank: Apprentice
Rating: 92%, 3 votes
I have a B60 and it does not have the "NOT READY" problem when I did the "priming" process. So I brought this B70 during Christmas this year, I had the exact "NOT READY" problem during the "priming" process like most of the people here. They sure DO have some engeineering/quality control issue here. No water was coming out and it looked like the pump had some kind of problem in getting water from the tank when the "priming" process was taken place. Instead of waiting a technican to call me back on Monday, I decided to ask my friend Google. It appeared there are a lot of people have the same problem and only ONE of the postings offered a solution and it WORKS!!! Here is the link and the extracted method in showing you how to reset the B70 so that you can retry the "priming" process. PS: You may have to try MANY times for the step #3 as described. http://www.all-about-coffee-makers.com/my-experince-of-keurig-b66-coffee-maker.html Fixed Not Ready Mode by: Anonymous Bummed - I talked to Keurig this morning (Dec 27, 2008). There are 4 steps to fix this: 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen. 2. Press "menu" once. Your LCD screen should say Brew 0:00. 3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly. 4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
GOOD LUCK :o)
Posted by: Harry at December 28, 2008 10:05 AM
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Aug 13, 2009
Not Rated)
cheryl_landi
Rank: Apprentice
Rating: 0%, 0 votes
I just called Keurig because my B66 wasn't going through the whole brew cycle and was not dispensing water. I told him i did the reset procedure found online... he said you really should NOT do that, unless instructed by a techinican, because it could be bad! While i was on the phone w/ him my keurig completely died! BUT- they are sending me a replacement out immediately! YEAH KEURIG! just a little FYI
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
Keurig says ready to brew but when we press the brew button nothing happens
Answer
It is not brewing. It turns on, sounds like it is going to brew and then cuts off.
Answer
my keurig is not brewing once cup size is selected. it says "brewing" but nothing is...
Answer
It will not stay on. I turn it on, it makes a loud whirring noise for 2-3 minutes, and then shuts... (More)
Describe your Coffee and Espresso... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
