Question about Canon USA - COPIERS - ImageRUNNER 2010F Copier
Printer does not print automatically. It prints manually
This network printer (Canon imagerunner 2010) is not printing, and it's not giving any error messages. when I click on print, everything goes as it always has, except, not paper comes out. then I go to the machine and press on print button (it's print/copy/fax machine) and then I press OK, and it prints the document.
  • 100 Answers
It may need a firmware update, new software, Also check that your drawer sizes are set right. If so you need a canon tech to visit.
Posted on Jan 11, 2009
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
How to change paper size from computer & not have to physically go to printer
when you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
Apr 14, 2017 | Canon ImageRunner 1025IF Copier with DOC...
Our network wont see our ir330 imagerunner for printing or scanning yet i can ping the printer and get a reply. i have not installed any software yet for the printer. should i install scangear?
the machine has the print server board and interface board installed? Canon machines need additional hardware installed to function as printers
the parallel port is not a print port
contact connecticutcopierrepair.com for more info
Feb 02, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to canon.com and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir 2200 print from oracle
ive had this before its under your printer setting tools you have to set that copier for tray 1 or letter turn off automatic
Sep 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Printing error
Try to printing a configuration page from the print board if this works check all your network cables then try to PING the copier by...
Go to START on computer
then RUN
then type "cmd"
then type ping
press the space bar once
then the ip address in full and press return
if your network is ok you should get a signal return
and NOT a timed out message
If your network is ok
Try deleting the printer and re-loading the print driver making sure the IP address is the same as the one on the configuration page.
If you require more help please get back to me
Thank You
Mar 09, 2008 | Canon imageRUNNER 400S Copier
Canon C3220 PDF print problems
http://www.adobeforums.com/webx?14@@.3bca0e93/7
Nov 12, 2007 | Canon imageRUNNER C3220 Printer
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
214 people viewed this question
old marine
old marine
