Question about Garden
Reverse on my 05 polaris rmk 900 dosent work
Mabey the tps?
SOURCE: polaris rmk 500 backfires when it gets hot then
Ok this sounds like a similar problem that I have had with a 500xc engine...This engine has been running fine for the last 5 yrs until a few weeks ago when it became a pig to start and when it did only run on one cylinder eventually running on both and when it gets to a certain temp would cut out and then not start again for 5mins, changed everything we could think of, checked compression, barrels fine, carbs clean new cdi, coil, plugs, leads, fuel pump and pipes, then someone came accross with checking the resistance on the temp sensor on the top of the head which were different values to the the book and on another identical engine, I borrowed a spare sensor and although still a pig to start it was an improvement when running, need to buy a new sensor to rule it out
, can anyone else shine some light on this?
Posted on Sep 04, 2009
  • 85 Answers
SOURCE: i have a 2000 polaris 800 rmk that i just bought and am not sure
With both of your questions the parts book is a recomendation for a specific condition. If you have 410's now and the spark plug looks like it's burning a nice caramel brown then you are fine. If the spark plug looks like it's burning white you need even bigger jets, if you are burning black then you need to go smaller. Always change them by one or two sizes and check again. As for the weights, the different weights change shift points of the clutch a heavier weight would cause the primary clutch to engage at a different rpm, I am in a stage of trial and error on which ones to use to make the clutch shift when and how I want it to.
Posted on Dec 30, 2009
SOURCE: polaris rmk mtn bike or victory vegas low mtn
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
Posted on Dec 01, 2010
acoates
  • 454 Answers
SOURCE: 2006 RMK 700 Polaris snowmobile. Overheating even
Hello, keeshamay and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your
snowmobile, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose your overheating
snowmobile
Get more great money saving tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Posted on Jan 13, 2011
SOURCE: 2005 POLARIS RMK RUNNING PROBLEMS
Check all electrical connections
Posted on Feb 17, 2011
How do you do the drive chain adjustment on my 2005 Polaris 900 rmk 159 track
To adjust chain tension in the chaincase, loosen the jam nut on the chaincase with a 9/16" wrench a few turns. Then turn the adjustment ***** in with your fingers until it can't be turned by hand anymore. Once that point is reached back the ***** out 1/4 turn and tighten the jam nut. Best of luck, Daniel
Mar 12, 2016 | ATVs
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
Reverse on my 2007 rmk is going into reverse on its own and toggling back and forth from fwrd to rverse winthen seconds wat shuold i be checking ?
My 07 RMK 600 did the exact same thing after a VERY wet ride on the sled deck. after i let it dry out it, then next trip we made it seemed to run fine.
were you able to identify the problem on your 07 RMK?
Jan 31, 2011 | Polaris New Genuine Polaris Snowmobile...
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
900 rmk going down trail and died No spark now
CDI box went out, or your stator poped. only things posssible, coils dont go out at the same time
Jan 25, 2010 | Polaris New Genuine Polaris Snowmobile...
I was full throttle going across a lake when boom the snowmobile stalled and dropped down. I opened the hood and the primary clutch was in 3 pieces and the belt was in pieces. Tell me what it would have...
those 900s had a recal for many things, one of which was very poor cooling to the clutches, they recalled them and put aftermarket vent kits, your clutches got really really hot and came apart
Dec 17, 2009 | Polaris New Genuine Polaris Snowmobile...
2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Feb 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
