Question about Activision Call of Duty 2 for Windows
Error during initialization: Unhandled exception caught
After installation and downloading everything required..i get this error messege..please help
3 Suggested Answers
  • 30 Answers
SOURCE: get a msg saying FATAL ERROR .Error during
cant help ya, maybe you can reinstall it
Posted on Jul 12, 2009
pinka29cena
when i stat the igi2 fatal error is show what could i do to solve it
Posted on Dec 18, 2013
Find problem in Autocad 2014 while opening a file Fatal error: unhandled delayload "modlr19.dll"Module not found exception at 75bad36fh
Try uninstalling and then run CCleaner to remove any tombstones left over in the registry. Once clean try a fresh install once again.
Nov 25, 2014 | AutoCAD LT 2014 for PC
Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information a
change PDF readers program.if yuo absolut want adobe acrobat uninstall it download new version.install that but be sure of get out all old files.in C\
Apr 01, 2013 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Fatal error
this error points to locked files during startup, only known to me solution is complete removal of autocad from the system, it as well be indication that insufficient or faulty memory in the system.
i would suggest removal of autocad, reboot, install ccleaner, remove of all junk and clean of registry, then clean re-install of autocad,
if you have less than 512mb ram on winxp or less than 1024mb ram on vista, it can be a problem as well.
Jul 26, 2010 | Autodesk AutoCAD 2006
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Unhandling error
How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Question : How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Answer : To correct an Unhandled Exception error received while editing a scan:
  1. Open the Control Panel on your computer and double-click Display.
  2. From the Display Properties window, click the Settings tab, and then the Advanced button.
  3. From the "DPI setting" drop-down list, select Normal size (96 DPI).
  4. Click OK and close all open windows.
  5. Restart your computer for the changes to take effect.
May 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Message appears at startup
I sugges you to download an Autoruns program it will help you to remove unneeded startup items.
Good luck
Feb 20, 2009 | 3Com Home Connect Lite Webcam
Hello i need help?
Hi and kumusta,
Initially, I would suspect that a malicious file was inadvertently inserted into your Windows startup. This could be caused some sites that autodownloaded into your system that they be made your homepage. Similarly viruses could also have caused this. Whatever the possible cause(s), pls try:
  • run your antivirus, scan and clean;
  • download, install and run Ad-Aware;
  • goto Start, All Programs, Startup and remove/delete all unnecessary entries (except perhaps your antivirus);
  • goto Start, Run, type "msconfig" less the quotes, OK, click on the Startup tab and uncheck all that are unnecessary (except perhaps your antivirus);
  • if you are having trouble performing any of the above, pls try doing them while in Safe Mode.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Sana maayos ang problema, if not, "Ask Me" again.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Video Game Consoles & Games
Unhandled exception error after installation
uninstall software and reinstall the software with usb cable not hooked up to the printer.
Dec 05, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Activision Call of Duty 2 for Windows Logo
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
