Question about Maytag MSD2651 HE Side by Side Refrigerator
My Maytag refrigerator (MSD2651KES) is leaking water from the bottom. What would cause that problem?
Maytag refrigerator (MSD2651KES) is leaking water from the bottom of refrigerator.
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
SOURCE: water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Posted on Nov 17, 2008
alex_salve
  • 78 Answers
SOURCE: maytag side by side refrigerator ice forms at the bottom of freez
DEFROST THE FRIDGE BY SWITCHING IT OFF FOR 2 DAYS
Posted on May 25, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
Maytag MFI2266AEQ Refrigerator is leaking water from the bottom right side. Why?
Do you have an ice maker, if so turn off the water supply to the fridge and see if the leak stops.
Nov 11, 2016 | Maytag Refrigerators
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
Maytag MSD2651KES the coils are iced over, both the freezer and the fridge are no longer cold. This is the third time in 3 years this has happened, having to replace the Defrost Thermostat and the Defrost...
It could be a faulty defrost heating element or a bad terminal connection somewhere in the defrost wiring circuit. Make sure the doors seal properly. ie. no gaps between the door seals and the unit when the doors are closed. Door seal leaks can cause coil icing. If okay, the heating element is not working properly (heating up) during the defrost cycle. ie. The ice on the coils never melts off the evaporator coils.
Aug 12, 2013 | Maytag Refrigerators
Maytag regrigerator MSD2651KES
Changing the 67006531 Water Inlet Valve is quite simple. If after
watching this short video you have questions please let me know If you want a service manual for this model let me know HERE. I can't post the manuals for everyone to copy. Thanks Sea Breeze
Video Here=> Refrigerator Repair - Replacing the Water Inlet Valve (Whirlpool Part# 4389177)
Nov 24, 2012 | Refrigerators
Model msd2651kes Water supply very slow. I can't find any kinks in the lines. Detached hose from back of frig and water just dribbles out. Maybe I hooked up water supply incorrectly when I first...
If when first hooked up the water line if you used a peircing type valve that clamps onto the cold water pipe it clamps on,tighten the screws equally on both sides till its tight around the pipe.Turn that handle in to peirce the pipe in a clockwise motion till it stops,it will peirce the pipe but be in the closed position, so open it in counterclockwise direction till it stops
Gene
Aug 05, 2011 | Maytag MFF2557KES 25 cu. ft. French Door...
Side by Side Maytag SS-2, water is leaking into bottom of freezer side and freezing, eventually leaking out.
defrost the freezer and remove the ice . then with hot water & a turkey baster force water through the drain in the back // when clear the problem is over .. this is caused by algi build up in the bott om of drain line .. mm
Jul 10, 2011 | Maytag Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Uhhhhhh
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Dec 22, 2009 | Maytag MBF1956HEQ / MBF1956HEW /...
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
96 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
