How to replace lid switch on Kenmore top loading washer, 23832
How does the top cover raise to get acess to lid switch assembly?
  • kloch57 Jan 13, 2009
    Unfortunately that is incorrect. After researching the issue, I fopund the cabinet has to be removed, found it on Youtube. You pull the endcaps off control panel to expose the screws, remove them, open console, detach the lid switch, remove two cabinet brackets and the cabinet is easily removed. Replace the switch, reverse the procedure and you are done. Trying to take just top of cabinet off results in damage and a disfigured cabinet. Saw it would not work your way early in process, stopped and researched and found solution another way. Thanks for the help anyway.
    Scholar:
  • 60 Answers
Just underneath the topcover approx. 2-4 inches from each outside edge there is a small clip. Push in on the clip one at a time while pulling up on the top. It will release.
Posted on Jan 11, 2009
  • tnmatt Jan 14, 2009
    Than why did you ask on here? My bad, too lazy to search!
I can't get the cover off of my magic chef washer to change the lid assembly. It seems to be very different from the other instructional videos I've watched. thanks Brad
Hello Brad,
On that washer to access the lid switch the top come um from the catinet to replace the lid switch. To open and raise the top simply place a putty in the seam between the front of the top and cabinet about a 1/2 to 1 inch in from the corners and depress clips that hold top to cabinet then once they are depressed in lifr up the top
Gene
Aug 17, 2011 | Magic Chef CAV2000AWW Top Load Washer
Model no. 23832, won't spin, lid switch is good and so is motor coupler. HELP
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Kenmore 2383x
Kenmore 22432 top load washer - how do i remove top to replace the lid switch
what are the 3 numerical digits before the period as in ( XXX.XXXXXXXX) the first 3 numbers tell you who produced it for kenmore,then i can tell you how its dis-assembled to replaced the lid switch
Mar 05, 2011 | Kenmore 24042 Top Load Washer
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loading Kenmore 80 series Model # 23832 washing machine. The washer will not spin. The motor is working, but the drum is not spinning. Is there a belt or gear that needs replaced? If so, what...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Sep 29, 2009 | Kenmore 23822 Top Load Washer
Do I have to replace lid switch on Kenmore washer or I can just short the wires? Thank you
you should replace the lid switch if it's broken - if you do clip the wires and tie them together, just remember that the machine won't stop when the lid is raised. it could be dangerous when spinning
Aug 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Kenmore 70 series
I am assuming there is no noise coming from the machine, if not check the lid switch. open the lid and look for a small slot in the top of the washer. With the washer set to run, press down on the slot with a screwdriver or something (make sure everything is clear from the tub) see if there is a clicking sound when you push down. If the machine starts you need a depressor piece on the door. if there is no clicking sound you may need something else. lets start with the simplest, like the door switch and go from there.
Nov 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
