Question about Husqvarna Sewing Machines
I cannot find a foot pedal and lead for my husqvarna classica 100
Please point me in the right direction or suggest where I can purchase a foot pedal or foot controller from for my husqvarna classica 100 sewing machine. Thank you.
  • 192 Answers
SOURCE: My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
Posted on Apr 23, 2009
  • 152 Answers
SOURCE: I have a Viking Husqvarna classica 100 sewing
You do not oil that machine with those holes in the top.
The Zig Zag problem is caused by a finger near the pattern selector that is just starting to stick. Take off the rear cover with the one screw located at the top rear of the machine. (lift the handle up to see the screw) Then pull the rear cover upward and slightly outward to remove the cover. Looking into the rear of the machine, you'll see a shaft about 4 to 5 inches long that the camstack moves up and down on as you turn the pattern selector on the front of the machine. The finger that is sticking is to the left of the shaft (usually it's silver), it has a spring on it. Don't remove the spring. Gently move the finger back and forth after you put some teflon oil on the top and bottom of the finger. Also try to move the finger up and down the shaft it's on as you move the finger in and out, it only has a small travel so don't force it. Your goal is to just get a little lubrication underneath it to free it.
Posted on Dec 31, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
SOURCE: I require the instruction manual for a Husqvarna Classica 105 Sew
I have a copy. If you still need it, I can e-mail you a copy.
Posted on Apr 30, 2010
  • 4 Answers
SOURCE: Power won't stop - Husqvarna/Viking 3600
Many older sewing machine (and some newer ones too) have radio-interference-suppression capacitors fitted in the foot controls to eliminate motor noise being radiated back down the mains power line. Many of these, especially the ones fitted across the rheostat (speed controller) in the foot pedal go partially or fully short-circuited, this meaning the machine starts sewing when the foot controller is plugged in. The solution is simple: get a qualified serviceman to take the capacitor out of circuit to see if that fixes the problem. If it does, then a replacement suppression capacitor of a suitable high voltage, at least 1,000V working, should be sourced and fitted. Just removing the faulty cap is not recommended and there is likely to be radio interfence spread all around the neighbourhood if you run the machine without the suppressor. The Radio Inspectors will not be amused. Good Luck.
Posted on Feb 27, 2012
The foot control on my husqvarna 545 viking sewing machine quit working. What's going on?
First not familiar with exact product , however troubleshooting is common.
This is if pedal can be unplugged and you have access to volt meter (these are cheap enough under $20 and have other uses to support purchase) , set meter to measure continuity, set meter to lowest ohms to start. Before using on pedal touch the red and black leads together, touching the result should be zero on meter, not touching infinity or blank. Connect leads in various manners to the pins or sockets move pedal. If your meter reads a high number while moving pedal you have an open circuit.
If you see the meter fluctuate as you depress pedal that would be expected ( normal) but then when fully depressed go high ( open) your pedal switch is faulty. The variation in resistance as you push pedal slowly is what varies the speed.
Sep 13, 2016 | Husqvarna Sewing Machines
Lost power control foot pedal viking scandanavia 100
Hello
You may be able to obtain a replacement foot pedal from you local Husqvarna Viking dealer.
Happy Stitching
Sewingirl/
Jan 28, 2014 | Husqvarna Scandinavia 100 Sewing Machine
Change light bulb in classica 100
I have a Husqvarna Classica 100 and need to lower the lightbulb guard so as to change the bulb. I have read the manual, but still cannot figure out how to do it. Any help would be greatly appreciated.
Feb 13, 2013 | Husqvarna Sewing Machines
Changing a presser foot on classica 100
Look at this page for a visual to help you determine the type of "shank" you have.
http://www.clotilde.com/pages/which_foot.html
Sep 08, 2012 | Husqvarna Viking 1
Viking husqvarna classica 100, thread tension
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
I have a Viking Classica 100 and the hook just
Yes, these parts should be replaced. Original parts are only available from an authorized Husqvarna Viking Dealer. The service/repair is very intense and should be performed by a certified Husqvarna Viking service technician through the Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 09, 2010 | Husqvarna Viking 1
Need Foot Pedal for Viking Classica 100
Any foot control will fit, you can get them at any sewing machine shop they are standard, only two wires to connect which is very easy
Nov 03, 2009 | Husqvarna Viking 1
I am looking for a manual for a viking husqvarna
Call Husqvarna at: 1-800-474-6437. They may be able to get you a photo copy of the original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
Bobbins for Husqvarna Classica 100
classica 100 requires special husqvarna bobbins available from husqvarna dealers.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
111 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
