Question about Canon FAX-L100 Plain Paper Laser Fax
Canon Fax L100 error 0088 - Canon FAX-L100 Plain Paper Laser Fax
  • 82 Answers
SOURCE: Canon Fax L100 - How to set time
simple,
open cover that is used for one touch speed dial buttons on the control panel, press the button called data registration, then look for keys that go up,down, left and right and use them to scroll to to initial settings and press the set key to choose the date and time and set the correct date and time and press the set key to complete or choose that function and the up/down or left/right to make changes.
thank you,
mikey
Posted on Apr 03, 2008
  • 64 Answers
SOURCE: Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Posted on May 21, 2008
  • 5 Answers
SOURCE: i've got error message on fax-l100 canon
I have been having the same problem from my cannon l100.
If you switch off the fax machine for 30min the switch it back on again the fax will resets its self and will clear this error.
Martin
Posted on Jul 13, 2009
SOURCE: Canon L100 fax machine
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
Posted on Oct 21, 2009
canontech
  • 1219 Answers
SOURCE: Canon Fax L100 has Comm Error. Seems to re-appear
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Posted on Jun 14, 2010
What is the error e225-002 on a faxphone L100 ?
Can't find exactly the error, but e225 indicates in internal error...unfortunately the 002 indicates exactly where the error is occurring and can't find that indicated anywhere.
Found a few suggestions that a firmware update can fix a number of e225 errors. Firmware can be download directly from the Canon website here.
Canon Support Drivers FAXPHONE L100
Failing that, Canon's direct support number is 800-652-2666
Hope that helps in some way, and good luck!
Jun 17, 2014 | Canon FAXPHONE L100
Fax L100 codice errore durante rx 0033
Information from service manual Canon L100:
Error Code 0033 :DCN was received through a non-normal procedure
Jan 18, 2011 | Canon FAX-L100 Plain Paper Laser Fax
What is a com 01 error?
Information from Canon L100 Service manual
Error code 0001 : The sender may not be using a G3 fax machine
Dec 23, 2010 | Canon FAX-L100 Plain Paper Laser Fax
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | Canon L120 Fax Laser Printer
I've got error message on fax-l100 canon
Martin
Jan 31, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon L100 Service mode
can't help with service mode, but what makes you think a white balance error?
Jan 17, 2008 | Canon FAX-L1000 Plain Paper Laser
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Canon FAX-L100 Plain Paper Laser Fax Logo
161 people viewed this question
old marine
old marine
