Question about Craftsman 4 Cycle Blower/Vac
Sears 10inch gas snowblower wont move but runs
I have a sears 10inch snowthrower/blower that has tracks and is self propelled it runs great but wont move.almost like its slipping.
  • 979 Answers
You may have a bad clutch assembly. Check it and then see if the belt is tight enough.
Posted on Feb 03, 2009
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
Craftsman model c950-52126-0 snowthrower wont move
I tried searspartsdirect and Sears doesn't show that model. Are you sure it's the correct model number ??
Is it gas, electric ... single stage or two
Have you tipped it up on it's auger (service position) and taken the bottom panel off to look inside and see what you can see ??
Jan 11, 2014 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Craftsman track snowblower
it depends on your drive system it its a hydrostatic tranny no it will not unless the engine is running and the lever is engaged
Dec 20, 2013 | Garden
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
Unable to obtain part no.631-0002 (track drive wheel) for my Craftsman modelC459-52128-1 snowthrower (no longer availabler from Sears). I'm searching for a business or person who would be able to sel
They are on EBAY. Check user ID ICANFIXITORSELLIT he has them posted. and they work great. they are made out of metal instead of plastic but are awesome.
Nov 17, 2011 | Craftsman Garden
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 11, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
Mtd snowthrower fuel line leak
Possibly cut a very short piece of the old fuel line off and put it back on the fitting with one of those small spring type hose clamps.
Feb 21, 2009 | Garden
Craftsman 4 Cycle Blower/Vac Logo
106 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
