Question about RCA 32V420T 32" TV
Screen stretched on rca tv
The screen is stretched from left to right you can not see any of the display and it seems to curve in the middle.
4 Suggested Answers
  • 4234 Answers
SOURCE: 32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Posted on Apr 03, 2008
  • 63 Answers
SOURCE: my rca sdtv model 27v414t, the picture won't fit
You are describing normal operation. I have a Samsung with the 4:3 screen aspect ratio and deal with the same issues. With a program that is broadcast as HD I have the "letter box" pic. since this is needed to amintain the 16:9 ratio it is formatted in. Some programs come up as only filling part of the screen & at times I find the zoom mode less objectional to view. Even if you have a wide screen set you still deal with programs that are not in the 16:9 format. Perhaps eventually all programming will be in a consistent format, but for now we just have to put up with it. The good news is that your TV is not defective.
Posted on Nov 19, 2009
SOURCE: Mitsubishi WS-55807 image curves concave at middle top and bottom
Try TvRepairKits.com. I just ordered one, I have that same model TV and it is the same problem. I will try to fix it myself as opposed to an expensive service call for repair.
Posted on Mar 16, 2010
I have hooked up my laptop via external monitor to a projector using an s-video lead and an adapter at my laptop end. The picture does show up, but it looks like its been stretched vertically and only the...
what resolution is your laptop display set to? try changing that and, the refresh rate, usually 60hz but you should have some diff options. if you have a vga display available try it and, if it works then the problem could be the SVideo port.
Mar 31, 2011 | Televison & Video
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
46" blurred screen and middle of screen is beveled
Yes,Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | RCA P46924 46" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Left side and right side are blury.
With projection sets, there is typically several settings for which you can display an output. You probably have a "wide" or "stretch" as a setting for the tv. What you want is normal, or some setting which doesn't result in a stretch. Widescreen projection tv's try to stretch 4:3 output into the widescreen setting, but usually this just results in the middle being in focus, and the outer 20% to be stretched on each side, bluring the edges.
Try to manipulate as many "tv settings" as possible. For most sets this is only available with the original remote. If you don't have the original remote, changing these settings could prove difficult.
Apr 05, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Stretched big screen rca
streched which way... up down left and right
try pushing left or right arrow keys on remote to change format.
Nov 18, 2008 | RCA D52W19 52" Rear Projection Television
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA 32V420T 32" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
