Question about Haier HPR10XC6 Portable Air Conditioner
Cannot remove front panel on haier HPR10XC6 i want to service the conderser motor
3 Suggested Answers
  • 157 Answers
SOURCE: Haier Model HPR10XC6 not blowing
those units are generally shipped with out service valves, check to see if compressor is running
Posted on Jun 21, 2011
  • 4736 Answers
SOURCE: I need a vent hose
If it's the same diameter and cut to length, yes it would. I would recommend using the aluminzed duct, rather than the plastic type.
Posted on Jul 05, 2011
Manual for my Haier Portable Electronic Air Condition HPR10XC6
go to www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 22, 2012 | Haier Heating & Cooling
Haier ac blinking red light
I have same exact problem.. Any luck?
Aug 20, 2011 | Haier HPR10XC6 Portable Air Conditioner
Water running out of small orifice in back of unit
If that small orifice you're speaking of is just above floor level. That's the drain plug for draining the tank. It may simply be loose and needs to be tightened or it was cross threaded when it was last drained and reinstalled.
In either case, turn the unit OFF and unplug it. Remove the drain plug and drain the unit as you normally do. Then reinsert the plug, and tighten it, being careful not to cross thread it or over tightening and cracking it. Although your model has an evaporation feature, there are times the bucket needs to be emptied.
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Haier HPR10XC6 Portable Air Conditioner
I need a vent hose for my Haier HPR10XC6 portable a/c. would a dryer one work? what size
Jul 05, 2011 | Haier HPR10XC6 Portable Air Conditioner
Haier Model HPR10XC6 not blowing cold. How do I recharge the unit?
Jun 21, 2011 | Haier HPR10XC6 Portable Air Conditioner
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
Haier 1260k error message no 7
Hi
Err 7 is a motor error. You can reset the error by first unplugging the washer and then try and follow the given procedure to resolve error 7 --
  • Disconnect the machine from power supply and stop the water supply as well.
  • Access the back of the machine by pulling it under the counter.
  • Now you’ll be able to see Phillips screws at the back panel, remove them to access the small back plate.
  • Now from that opening you’ll be able to see motor and motor connector. Plug the connector back on to the motor if it is unplugged or loose. There is only way to fix it so you will not get wrong.
  • Now reconnect the machine with the water supply and plug it into the power supply.
  • Select only the quick wash cycle to test the machine.
After this if the error is not resolved then its an issue with the motor, and yu'll need to get it checked from a service tech.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 05, 2009 | Haier XQG50-QF802 Front Load Washer
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Haeir HRF10 refrigerator
Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
Mar 01, 2008 | Haier HRF10 Top Freezer Refrigerator
Haier HPR10XC6 Portable Air Conditioner Logo
37 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
