Question about Refrigerators
My westpoint rgk143 tropical just stopped working. the lights come on but the compressor does not run.i left it unplugged for a day switched it on and it ran and got cold then cut off again.
CMV9
  • 594 Answers
SOURCE: GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Posted on Aug 01, 2008
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
relaga58
  • 158 Answers
SOURCE: Fridge running but not getting cold
it seems like you have a minor gas leak
Posted on May 07, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
SOURCE: Compressor makes a running noice for 30 secs and then clicks
I got the Compressor Overload relay Assembly replaced and the compressor started to work.
Posted on Sep 06, 2009
Testimonial: "worked for me"
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a westpoint tropical WRK1802g.1 the freezer always freezes but the fridge side stops working at times and then water runs out from the buttom of the fridge side
If you also have ice buildup in the freezer your temps are not as low as what they should be and your refrig compartment will be warm.
Jul 19, 2015 | Refrigerators
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Hi, there! I have a WESTPOINT no Frost NF 120 and couple of days ago the fridge just stop working. The freezer is ok still working as usual, but the lower part is completly worm. The compressor is working,...
It's the Timer ..a device found on the left of the compressor at the back ..a few wires goes insinde. it has a watch gear mechanism..and a miniscule ant can stop it ..
May 14, 2011 | Refrigerators
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
I have a Fisher & Paykel E522B fridge that has suddenly stopped cooling.....it appears that the compressor is still working but both the fridge and freezer are warm.....as we live in a remote area of...
Check fans in freezer and near compressor. Is compressor running continuously or clicking on and off? If fans are running and compressor is running continuously, your problem is most likely within sealed system. That would require a technician and may not be cost effective to repair.
Sep 23, 2017 | Fisher and Paykel Active Smart E522B...
May 07, 2009 | Refrigerators
Westpoint Dishwasher
I put the mahcine on as normal but it does not go past the first cycle of the red flashing light?
Sep 08, 2008 | Dishwashers
Refrigerator not cooling
Did you lay this refrigerator down on its side or back when you were moving it? Is there a chance one of the tubing lines in the rear or under the refrigerator got damaged and allowed the refrigerant to leak out? If yes to either of the questions you will need a service technician to do a sealed system repair.
There is probably a fan under the refrigerator near the compressor that should be running any time the compressor is running. If it is not running when the compressor is running the system will not work well.
supertechks
Mar 28, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
