I need to replace the ink cartridge in my Visconti Rembrandt ballpoint pen?
2 Suggested Answers
gisvc
  • 40 Answers
SOURCE: I replaced the cartrigde in my hp300, but is says load pens.
hi, i contacted hp systems the pins the printer are refering to is the following below. the said if this don't solve the error contact them with possible parts replacement. good luck! ISSUE: The Line Interface Unit (LIU) must be removed for troubleshooting or replacement on an Officejet model 2890A, LX or 300 series. SOLUTION: There are catches that must be released before the LIU can be removed. Follow the instructions below: Removing the LIU
  1. Unplug the unit from the power outlet.
  2. Open the top of unit to access the ink cartridge area.
  3. Stuff a tissue into the black plastic opening just to the left of the print carriage as shown in Figure 1. This will keep any ink that is in this area from spilling into the unit and damaging it. Figure 1: Inserting a card to release the LIU c00224954.jpg
  4. Turn the unit until it is resting on one side and the bottom is accessible.
  5. The LIU is normally removed with the aid of the LIU removal tool (part # C4661-40007) that is included with a replacement LIU but can be removed without it. Here are the two methods:
    • With the LIU removal tool: Line the tool up so that the pins push against the catches on the LIU and press down to release the catches. While holding the tool pressed in, apply pressure to slide the LIU out of the machine as shown in Figure 2. Figure 2: Removing the LIU with the removal tool c00224955.jpg
    • Without the tool: Use a pen or small screw driver to release the two catches (one on either side) while at the same time pushing out on the LIU as shown in Figure 3.
Figure 3: Releasing the LIU c00224956.jpg
Posted on Mar 30, 2009
How do I reset the ink so it recognizes a refill cartridge that is not the original epson ink cartridge. It was working just fine for days, and now it will not let me do anything. Is there a bypass...
The information I recieved.
Tuen the printer off. Open printer cartrege well.
Push row of cartreges manyally to the center of the printer bar. Remove cartrege in question.
Remove the outter lable on the cartrege. (It will peel off) be careful not to peel the plastic window off the cartredge or it will be useless.
Replace the cartrege back into the well to reinstall.
I did this SEVERAL times (everything up to removing the label but reinstalling) before FINALLY, I recieved a message indicating the cartrege was not a genuine Epson cartrege...do I wish to continue?
It appears in the window on the printer.
Mar 02, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
How do I reset the chip on my ink cartridge for a epson wf 2540?
You're better off buying the auto reset replacement cartridges. Word of warning: Epson printers "SPY" on you and tell you that by putting in the compatibles, you will void their warranty. Second Warning: DO NOT download any Epson firmware upgrades because they will wipe the compatible chips and render them unusable. Always keep your old, used epson cartridges in case you need to reset the printer with the original chips.
Feb 14, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Do digital pens have other colors of ink or are they all the same?
You can buy replacement ink cartridges for your digital pens, but while you are writing you can only have one ink cartridge in the pen.
Sep 30, 2013 | Computers & Internet
Swarovski pen won't write
Did you get an answer to this as my Swarovski pen is doing the same?
Oct 05, 2012 | Swarovski Crystalline USB Key Ballpoint...
Faber Castell 148730 rollerball has been sitting unused for a few years and now won't write (no ink flow). There must be ink in the barrel because it was hardly used. Is there a way to restore the ink...
You can try running hot water over the tip of the pen for about a minute, then test the pen by rubbing it on a rubber surface. Hopefully that should loosen up the ballpoint and allow ink to flow freely again
Apr 28, 2011 | Faber Castell Graf Von Classic Rollerball...
I have a Corum ballpoint pen retractable, it has flags on the clip, body made of stainless steel, the clip has lost its springyness and is free to open and close without any spring pressure, and also the...
Hi Stuart,
I have the same bp as you. Why donot you ask Corum if it is to be repaired. Maybe they can tell you who the manufacturer of this pen was. I think Delta or Montegrappa was the manufacturer. Mail to cdubois@corum.ch. She was in 2008 working for Corum when I asked Corum more info about this ballpoint.
Regards
Wim Ammerdorffer
Oct 14, 2010 | Corum Watches
27 people viewed this question
jasbo
jasbo
