I need to reboot my acer laptop 250xc i need to restart the laptop but i lost my restore disks what do i do
  • hardtymessen May 11, 2010
    Give us some kind of Background, That might be a good start ?What did the PC say was the reason for shutdown.Last error you saw on the screen?I,E.says improper shutdown, windows will now shutdown?
    Do you have a windows disk that goes with your system?Have you already tried to reboot?Have you
    installed new hardware, new software?If any of the answers was YES? Then lets redo? First if the answer was hardware,Do not power up PC until all questions are answered?Don't plug it in,Unplug it.
    No battery power on?If you can undo any hardware additions ,without power! If not leave it and call a tech? Software if this is the reason for shutdown, is the disk still in the pc?No power? SEE it stays like this?Check to see if you would have a small hole, next to the drive normally it would be under it! We are still without power! The reason for this hole under drive is access to drive.What I use to access is the
    Drill bit the same size as hole! You should still be without power!!You insert the part of the drill bit that
    you put in the drill !! You take it gently by wrapping it with a dry cloth where you touch drill bit?Insert
    slowly when you reach the lever for opening th drive .You will feel a small resistance then the lever
    will go on in and drive is open? If this is very hard don't push it? Call a tech?When you get it out?
    Check disk see if damaged scratched,Put in paper wrapper Name it ,not to use?Will PC start on Battery?If not plug in adapter? Find a windows disk to match the one on PC ?Now put Windows disk in Drive.Power on PC Be ready to shutdown,cut power for un expected?Some times the normal
    thing the cmos will do is go to the window for last known good confguration..other is do you want to start windows normally?We don't know what you did to your PC?The best answer after we removed what we thought was the answer.Is think positive,start with last known good,or normally?(Email me) ,
    before you take drastic measures?Always have a pencil and paper handy,write down any error the PC says, every thing is important,Your errors will generally tell you the diagnostic?
  • 77 Answers
You need to get a licensed version and reinstall the operating system or maybe try to call acer and asks for the disks.
Posted on Sep 12, 2009
I wish to restore my acer 5742z back to factory settings. I have the original disks 1 to 4 also an app disk which I received with my laptop. But I'm not sure what to do.
Restart the laptop and enter the BIOS settings. Set first boot device as CD/DVD ROM.
Restart again with your disc labelled1 in the drive. Follow the prompts.
WARNING
All data will be lost!
May 14, 2015 | Acer Aspire 5742Z 15.6 Inch Laptop Intel...
How do reboot my acer no disk
To access the recovery partition on your Acer computer for a full restore, follow these steps:
1. Power on the Computer
2. At the white ACER BIOS screen, hold the left ALT KEY and press the F10 key simultaneously to start Acer eRecovery.
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK
5. From here, the eRecovery process will replace all the data on the C:\ partition and restore the factory image.
6. After eRecovery has run, press OK to reboot.
NOTE: All data will be lost during this process and your computer will be brought back to it's original factory state and settings.
If this fails because you have deleted the recovery partition or changed the hard disk due to failure you will require a restore CD.
The Restore CD costs approximately $19.95 (plus taxes) including shipping. If you have a unit from US or Canada, you may purchase the recovery disc from Acer store : Acer Store
If you have purchased the computer in any other country, you may contact Acer support here : Acer Global Support
Feb 18, 2015 | Acer Aspire Computers & Internet
How to reboot my acer v3 series?
Reboot or Recover? If you have a Factory Recovery Partition, use this procedure, a Recovery will return your Laptop to the day it came out of the box, YOU WILL LOSE ALL YOUR DATA, and you must install ALL Windows, Acer updates and software you installed, a Restore will return to a date selected, if your Laptop has Restore enabled in software. Acer Restore/Recovery Procedure: http://panam.acer.com/acerpanam/desktop/0000/acer/aspiree360/aspiree360faq40.shtml
Apr 17, 2013 | Acer Computers & Internet
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
It wont reboot, keeps asking for reboot disk for which i dont have because it was a gift
Reboot means restarting the pc after a simple power off - so there is no reboot disk.
If you are referring to recovery or reinstall disk then you can order a new one from Acer - for that go here
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Aug 16, 2011 | Acer Aspire 5330-2339 Notebook
Cant put factory settings on my acer one
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process. If there is not a disk,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls rate..thanks
Feb 22, 2011 | Acer Aspire One PC Notebook
How resstore my acer aspire to factory settings?
1.Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive.
3.Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted.
Feb 21, 2011 | Acer Computers & Internet
Error 0xd000000d restore failed
then u will have to format your c drive and then boot it again and for more info contact http://tinyurl.com/m7ghqz
Jun 20, 2009 | Acer Aspire 5100 Notebook
Trying to restore my system
Just use original OS and repair OS
Dec 07, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
