Question about Crosley Audio Players & Recorders
I have a Crosley Re2832 turntable/CD and radio system. The radio wont work and i was wanting to disassemble to find the fault, (blown fuse or similiar) i am not sure how to disassemble, any advice would be appreciated
  • 104 Answers
SOURCE: The turntable for Crosley Radio CR66 will not work.
http://www.archive.org/details/Turntable_Belt_Installation
Posted on Feb 22, 2009
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
  • 133 Answers
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Posted on Aug 08, 2009
  • 69 Answers
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
  • 298 Answers
SOURCE: my Crosley Radio CR6007A-MA Recording
I'm not familiar with this specific turntable but there are some general tests that you can try. As with any problem try to identify the source of the problem by working through an elimination process.
  1. Does the problem occur at all speeds or just one, which would indicate an issue with the belt drive system.
  2. Does it squeak continuously or only at certain points as the turntable rotates? Put a marker (a lump of blue-tac would work well) towards the edge of the turntable and note the point(s) where it squeaks.
  3. Rotate the turntable by hand with the power switched off, vary the speed you rotate it at. Can you feel the squeak as well as hear it?
  4. Is the turntable on a level surface and is the turntable itself level (parallel) with the base - if it is not this might suggest that one of the suspension mounts has failed. Peer under the edge of the turntable all round to make sure it is not rubbing against the frame / base.
  5. The turntable is driven by a belt system off a separate electric motor. Usually these motors are hung from the frame on a sort of elastic band arrangement. These bands become perished and can break or just stretch unevenly, which causes the motor to hang at a funny angle. Sometimes this can result in either the pulleys rubbing against the side of the frame (would normally be a fairly continuous squeak). At lower speed settings (e.g. 33 rpm) this may also cause the edge of the drive belt to rub against the bottom of the larger (45 rpm) pulley above it. If you can't find a supplier of the correct replacement motor suspension band you may be able to fix it with ordinary rubber bands but it may take a bit of fiddling to get the motor perfectly level at exactly the right height.
  6. With the motor running and the turntable rotating gently press on the rim of the turntable with your finger as a brake to slow the turntable down slightly. Does the squeak increase or decrease in volume or pitch? If it gets louder or higher pitched that probably means that the drive belt is slipping slightly (in which case some records may sound a bit slow when you play them). You can either replace the belt or purchase a can of 'belt dressing' spray (obtainable from most good tool shops) and apply a light coating to the inside surface of the drive belt - don't over do it. The best way to do this is by rotating the turntable by hand whilst gently squirting a little of the spray onto the belt close to the point where it goes on to the pulley on the turntable drive spindle. Take care not to get the spray on any other moving parts or the electrical components as it is sticky and hard to clean off. If this is the problem you may need to re-treat periodically.
  7. The motor and belt drive system may be accessible either by lifting off the turntable deck (platter) itself or by turning the whole thing upside down (make sure you secure the pick-up arm before you turn it over!) and unscrewing the bottom of the case. Some turntable platters have viewing holes in them which are revealed by lifting off the rubber mat.
  8. Gently slip the belt off the pulley wheels on the motor and on the bottom of the turntable spindle. Check the pulleys for any lumps of dirt or fluff that may be causing problems. Also check that the drive belt is clean with no lumps or flat shiny spots. If the belt is worn replace it.
  9. If appropriate turn the turntable up the right way again.
  10. Rotate the turntable by hand. If it still squeaks the problem is in the turntable bearing and may easily be solved with a bit of lubrication. Some manufacturers will supply a little tube of special grease. If you don't have this a bit of Vaseline /petroleum jelly will do quite nicely. Don't use a silicon based lubricant like WD40 as this will dry out again over time.
  11. Try rotating the motor spindle by hand - if it squeaks there may be a problem with the motor bearing. These are not usually serviceable and will need replacing.
  12. With some turntables the belt runs through some little guide wheels between the pulleys on the motor and the turntable drive spindle. These may need lubricating with a little VERY light oil. Sewing machine oil is perfect for this. Only use a tiny drop applied to the axle of the guide wheels with a very fine paint brush. Don't use to much or use anything in a spray can as it might get on the surface of the pulley wheels where it will contaminate the drive belt and cause it to slip.
Posted on Jan 30, 2011
Crosley radio CR248 can not get anything to work display screen shows ON but nothing will work
Type " Crosley CR248 user manual " into search engine and it will show sites to get manual. Some radios have 2 fuses in them. I could be blown. If you attempt to check the fuses... UNPLUG RADIO !!!!!!
Nov 21, 2015 | Crosley Audio Players & Recorders
Need schematic for CR73. Only radio works.
I'd like to see the schematic/parts manual, too.
Mar 01, 2015 | Crosley Conductor CR73 Turntable
CD will not finalize
No-way should it take that length of time to finalise anything. My DVD recorder only takes about 3 minutes at the most to do a 4 hour disc! CD are only 80 minutes max. I suspect you have an electrical fault on the unit. I would take it to the nearest Crosley Repair place.
Mar 27, 2014 | Crosley CR248 Turntable
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Crosley CR24 transformer rating
As transformers are Safety parts they must be replaced by the excat same part or one that is approved by Crosley. You should not attemp to use another transformer unless it's approved by Crosley. Otherwise it could become a fire hazard.
You can contact them here:
http://www.crosleyradio.com/Support.aspx
Nov 17, 2012 | Crosley Cr42 Turntable
Crosley cr704
I suggest you return it to the place of purchase, this is a manufacture fault.
May 26, 2012 | Crosley CR704 Shelf System
Crosley music centre has fault on record player due to turntable not working
If the unit is belt driven, (sometimes hidden) that is common cause of turntable failing to turn. Either belt comes off or is deteriorated.
Apr 27, 2010 | Crosley CR711-BK AutoRama Retro Turntable...
Aug 07, 2009 | Crosley CR248 Turntable
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Apr 01, 2009 | Crosley Audio Players & Recorders
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
