Question about Mitsubishi WD-62528 62" LCD HDTV
I have a misubishi WD 62628 projection tv when i hit the device button the screen turns blue and then shuts off any ideas
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
  • 8457 Answers
SOURCE: I have a 52
Ur LCD inverter board it dead,need it replaced,U have light go to LCD Screen right?
Posted on Nov 22, 2009
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
There is a line right in the middle of the tv going vertically.. the left side is fine but the right side is like 3d tv.. why is that.. Model # WD-62628--- S# 117086... Mitsubishi
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My misubishi VS-50603 just shows a blue screen
Press the AV button on the remote, it will alter the interface with your receicevr. It will automatically pick your receiver if it is sending signal properly. If this doesnt work try another tv on your signal box to see if you get the same problem. Bet its the AV button though. Best of luck dave.
Aug 02, 2009 | Mitsubishi WS-48311 48" Rear Projection...
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Oct 03, 2008 | Televison & Video
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62528 62" LCD HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
