Question about Intex Ultra Frame Rectangular Pool Saltwater2000gph Pump System 24' x 12' x 52" Complete Pool Set
When filling pool the top seem to move towards the centre of the pool,How do i stop this.
    Habit-Forming:
  • 51 Answers
As the pool fills more te pressure against the walls will push them back out again, I wouldn't worry too much about it till you have it 3/4 full.
Terry
Posted on Nov 30, 2012
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
The Hayward creepie crawlie that cleans our pool works fine until it comes to the steps - then it stops - head towards the steps - and if it does move again, it turns over. Do I need to get a rebuilding...
Make sure there is extra hose and extnsion cord to allow the pool cleaner to manuver around the entire pool floor. I don't know why the pool cleaner has problems with steps, was there a tramatic fall down a flight of steps or something.
Aug 12, 2009 | Pool & Spa
The booster pump is running but low pressure
this could be two problems first is pump basket filled to top with water if not you have a air leak check all connections the other is filter is dirty especially de filter backwash hope it helps
Jul 08, 2009 | Hayward Pool & Spa
Our KK. will work great for maybe 5 minutes, but then stops. It is still chugging, but does not move. Had this problem last summer and bought a new KK. Had the pool replumbed. Have put new gasket on leaf...
There are a couple of things that will cause Kreepy to not move. Basic things to look at to resolve this issue:
1. Check the Footpad, the very bottom part of the cleaner, there should be raised sections on the clear rubber ring. There should be texturing on those sections, should feel like a soft sandpaper. If the sections are smooth, that needs to be replaced.
2. Is the Seal flat on the pool surface? If not, you may need to move the first weight about 8 to 10 inches from the Swivel Head.
3. Does the cleaner stop moving in the same area? When your system is running, can you see the water "rippling across" the top of the water from the return lines? If so, the issue may be your return lines. The cleaner follows the hose, so where the hose floats the cleaner will follow. If the return lines are not allowing the hose to move, then the cleaner will stop moving. Pentair recommends that your return lines should be angled downward at a 4 to 7 o'clock angle, all going in the same direction. This will take a day, or so, to re-direct the flow of water in the pool. However, by moving the flow of water from the top, or toward the center of pool, to a downward circular movement will allow the hose to float freely around the pool.
Jul 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
Robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Apr 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Intex Ultra Frame Rectangular Pool Saltwater2000gph Pump System  24' x 12' x 52" Complete Pool Set Logo
114 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
