Question about Tasco Optics
Instruction manuals for tasco 4-16x50 AOE scope
  • 117 Answers
SOURCE: Where can I buy a sunshade for a Tasco 6-24x50 AOE
Burris makes excellent sunshades.They are available from Midway at www,midwayusa.com.Midway has about everything for the hunter and target shooter.Sunshades are relatively inexpensive
Posted on Mar 25, 2009
  • 44 Answers
SOURCE: where can i get an instruction manual for the
Contact Tasco at:
1-800-423-3537
Posted on Dec 30, 2009
agent91
  • 2100 Answers
SOURCE: I need the instruction sheet for a Tasco Scope
Go to my profile and look at my scope tips. agent91
Posted on Mar 09, 2010
SOURCE: I need a scope guide instruction sheet for the Tasco 28a
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright.
2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim.
3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading.
4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result.
5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline.
6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line.
7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle.
WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY
At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments.
8. Restore the stud tension by pressing the end of the spring.
Posted on Nov 05, 2010
SOURCE: tasco scope
Sight in rifle.Put top(elevation)cap back on with the"0" facing back.Be careful not to make it "click"as this will change point of impact.The way this works is you aim at animal and adjust the power(3-9)until the animal's body is between the 2 lines.Look in the little window on eyepiece to see distance of selected animal.Then click top knob to the correct distance(200,300,etc.)This should raise bullet impact for that distance.I've had this scope on a .270 since 1980 and never used this feature.(I only bought it because the scope was on sale)
Posted on Feb 06, 2011
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
Manual for tasco 2-7x 32
Here is a generic Tasco scope manual, since you did not provide the model number: http://www.tasco.com/products/manuals/TascoGenericRiflescope6LIMwebversion.pdf
If you have the model number, the reference manual may be available here: http://www.tasco.com/pages/instruction-manuals/
Good luck.
Apr 18, 2015 | Tasco Optics
Where can I buy a sunshade for a Tasco 6-24x50 AOE scope?
Mar 16, 2009 | Tasco Optics
Tasco scope manual
The manual is here under "Generic Riflescopes". It is a .pdf file.
http://www.tasco.com/support.cfm
The Tasco site for Riflescopes
http://www.tasco.com/section.cfm?s=Riflescopes
Feb 01, 2008 | Tasco Golden Antler 3 - (9 x 40 mm)...
Where to find manual or diagrams for Tasco scopes
Oct 21, 2007 | Tasco Golden Antler 3 - (9 x 40 mm)...
Optics Logo
64 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
