Question about HP LaserJet 2420 Printer
HP 2300 dtn error 49.0665 - HP LaserJet 2420 Printer
4 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
Posted on May 24, 2009
  • 12 Answers
SOURCE: Error 49 4CO2 Service Error on a HP Laser Jet
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
Posted on Nov 22, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
Jan 05, 2010 | HP LaserJet 4350dtn Printer
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
HP inkjet 1100 dtn network problem
i want start bussines of computor hware n sware i like to import directly
but dont have enogh fund i
Apr 29, 2009 | HP Business Inkjet 1100dtn Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Driver installation problem for HP 5400 DTN
Sorry
This printer is not supported by Windows98
So HP is also not provideding Windows98 drivers
Just try to work out with Drivers for Win2000
Jun 02, 2008 | Office Equipment & Supplies
HP LaserJet 2420 Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
