Question about Home
Can you help me fit a cedo sorrel toilet seat
2 Suggested Answers
SOURCE: can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Posted on Jan 15, 2010
Hi, I am replacing a rounded BTW toilet seat and the measurements are: between holes=150mm, width=370mm, length=430mm. I bought a Ceso Rue Softclose from B&Q as per this description http://w
I believe the European standard for distance between fixing holes is 155mm +/- 10 mm. I am not familiar with the actual products you are using, but often these holes are slightly oversize. Your seat may fit depending on this, as well as on the actual diameter of the fixing bolts. You have two options - try it or not. If you don't try it I assume you'll return it. If you do try it and it doesn't fit, you'll return it. You might as well try it, because if it fits, you're done! Good luck.
Dec 01, 2014 | Home
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
New toilet was installed in my apartment and I don't like the seat. Do you have different seats available? maybe a seat cover?
you can change out the seats any oval should fit an oval toilet and a round will fit a round toilet
just go to your homedepot, lowes, ace, etc. and pick out the 1 you want.
Nov 15, 2010 | Villeroy & Boch 9957 S1 Aveo Toilet Seat &...
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
Just bought a cedo rue soft close. any idea of order of washers going on etc as instructions unreadable
Metal peg fixing goes "into" large plastic "cup" washer. Metal fixing now goes through holes in toilet pan sitting in the "cup" washer. From the bottom push up the thin round plastic washer, convex side towards the hole. Next the oval shaped thick washer flat side towards the hole. This has a cup shape into which the final plastic screw fitting pushes into (like a coax plug on the TV aerial). This will push up the thread into the cup where the sides force the thread to grip. Finger tighten so that you can still move the metal fixings from the top. Line up the toilet seat holes and push fit onto the pegs. It may take a smart thump to get them fully seated. Before tightening with the supplied black plastic spanner" make sure the large "cup" washer on top has not got trapped under the metal fixing. If all is ok line up the seat and tighten.
Dec 24, 2009 | Home
Can you help re fitting cedo rue toilet seat
Dec 08, 2009 | Home
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Nov 29, 2009 | Duravit Home
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Home Logo
330 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
