How do I pull bowl out of LG WF-T502A
Can I pull the bowl out of LG WF-T502A without pulling motor off the bottom.??????? How do I do it.?????
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Water dripping out of a tubular part of outer plastic bowl.This is at the right rear, when viewed from the rear. It is an LG WF-T657 top loader
the plastic tube for the water level control is in that area
check for it to be attached , cracked or loose
Oct 26, 2016 | LG Washing Machines
Ran it out off gas, refilled it now runs rough
very likely that there was some trash in the bottom of your fuel tank and as it pulled the last bit of gas through it could have clogged the fuel filter, of the carburetor. Without knowing the make and model its possible there is no fuel filter some push mowers have a straight fuel line to the carb. If that is the case, on the bottom of the carb there is a bowl most mowers it has a bolt in the bottom middle of the bowl I would remove the bolt and drop the bowl, clean with a wire brush and carb cleaner and reinstall the bowl. I believe that will most likely solve your problem. If it doesn't or you have any questions please leave a comment I would like to help you resolve your problem!
Oct 01, 2015 | Garden
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
Where do i put in the fabric conditioner in my LG WF-F5700PCX
should be a little cup that pulls out on the top of it if not look inside for a sliding cup it may just get dumped in as well ...
Apr 08, 2011 | Washing Machines
HI, my Fuzzy logic WF -T655th is not draining, the motor doesnt sound like it is running. The spin cycle will try to spin if there is a little bit water is in the drum. have checked the hose and the...
BELOW ARE STEP BY STEP RECOMMENDATION ON HOW TO SOLVE THE PROBLEM OF YOUR WASHER THAT HAS FAIL TO WORK AS EXPECTED.
However,if you are having problems with either not draining or spinning, with your front load or top load washing machine, then you need to realize that they can be interrelated. Mostly in that if your washer is not draining the water it will not spin at all or at least not properly. There also can be others problems that will stop or slow down the spin, but the water not draining is the most common one.
So, if you are stuck with a washer that is full of dirty stinky water then here are some things to start checking.
First get that shop vac out or a bunch of rags and a bucket. The water needs to go. The shop vac will pull the water out the drain hose. Just remove it from the standpipe and place the nozzle in the hose and pull the water through the pump and into the shop vac. Of course if you cannot pull the water out this way, you already know that the pump is blocked or clogged, then just vac out all the water you can from the inside of the washer.
If all else fails, remove the front cover and take off the hose going from the tub to the pump. Yeah, water will go all over, but that is what the rags and bucket are for.
When the water is gone, you can then pull all the stuff out of the hose and pump, that are causing the problems. Most of these pumps are very easy to take apart and clean out. This will make sure that there isn?t anything inside the pump that can stop it. They are not very strong motors and something like a toothpick may stop it.
Now, where this get tricky is that there are sensors that check the water level and adjust the spin. If your water is not draining, your washer will not spin either.
For many washing machine problems that are drain and spin related, this simple cleaning will solve your problem. But there are other possibilities.
The lid switch is the old problem that keeps raising it?s ugly head on all washers. Bottom line here is that if the washer thinks that the door is open, the things don?t work right. Check out the door switch to make sure it is operating properly.
Make sure the new front load washers are on a good solid level surface. If the machine can move around then the sensors will often sense the movement and not allow the machine to reach full spin speed. Some manufactured bases may not be stable enough to give correct readings to the machine. If your washer is moving around, then fix that problem.
The timer can also be a problem. Many will wear out and then get to a point in the cycle, then not advance any further. Also the computer controlled sequencers can also get glitches and may need to be reset. You can check out the timer by manually advancing it, and the computer reset procedure will be in your manual that you received with your washing machine.
By going through this check list you can check out the problems that most handy persons can handle in the home. To make sure you have a the best chance at a trouble free washing machine, make sure that you do not leave anything et into your washer that will cause it harm or plug it up.
Good luck and thanks for using fixya.
Jan 22, 2011 | LG WFT1071TP Top Load Washer
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
LG WD 3243RHD
The crackling noise you're hearing is something is inside the drain pump and hitting the obstruction.  It's possible that the drain pump has been severely damaged to the point that the pump will have to be changed.  You will need to have a qualified LG technician diagnose the problem.
May 06, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Stuck Grinder Bowl
This seems to be a widespread problem on units manufactured in 2007 and later.
Unplug the unit from the AC outlet. Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Plug it into the wall outlet and use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom; avoid making grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem.
BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Apr 14, 2008 | Cuisinart SS Grind Central, removable bowl...
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
