Question about Video Game Consoles & Games
Connecting the Panasonic SA-PT70 to the XBOX 360
4 Suggested Answers
  • 63 Answers
SOURCE: XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Posted on Nov 25, 2007
SOURCE: CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Posted on Apr 30, 2010
  • 1139 Answers
SOURCE: I cannot connect my Xbox
Please try the following solution to reset the display :
1. Turn your console off.
2. On the Xbox controller press and hold the "Y" button and the right trigger.
3. Turn the console on using the Xbox guide button on the controller, NOT the power button on the front of the console.
This should now reset the display back to standard and you should be able to set your video up properly.
Hope this helps and thank you for using FixYa
Posted on Jan 06, 2011
Panasonic SA PT70 won't power on? Any ideas? The power cable has been checked and isn't fault. The power button clicks as it should when you turn it on but nothing happens.
Short circuited component/s at its audio output stage circuit. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 19, 2016 | Panasonic Audio Players & Recorders
Ok, my router is way in the other room and I want to connect my Xbox 360 to the router for XBOX LIVE. The thing is, is that I can't find a way to get something to extend the wire that's connecting to both;...
There are several solutions to your problem .
1. Run Ethernet Cable from an attic & drop either end down in the walls of the two rooms . Hardwiring is always going to give you the fastest , most stable connection .
2. Purchase a set of Power Over Ethernet Modules , you then plug your ethernet cable into your Xbox 360 on one end & the Power Over Ethernet Adapter on the other end , then plug the " POE " Adapter into a standard electrical socket . You will do the exact same thing on the other end with the Router this time . It should connect just as if you ran a single ethernet cable between the 2 devices .
3. You can use a laptop or desktop pc with a Wifi connection & Ethernet port to Wifi Tether / Share your Internet Connection . Just do a google search on Wifi Tether Xbox 360 or check out some of the videos at
http://www.google.com/search?q=wifi+tether+xbox+360&hl=en&prmd=ivnsfd&source=univ&tbm=vid&tbo=u&sa=X&ei=l_SoTfyFI4-usAOT1PX5DA&ved=0CHQQqwQ
Apr 16, 2011 | Microsoft Xbox 360 Console
Apr 30, 2010 | Microsoft Xbox 360 Console
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Need to connect xbox 360 to panasonic sa-mt1
If you want to play 5.1 sound, and you got to need this fiber optic cable(black single cable)..with reciver decoder with optical on IN, to connect the xbox 360 machine on, and the high defintion cable of the xbox.
Feb 19, 2009 | Panasonic Home Theater System System
Nov 25, 2007 | Microsoft Xbox 360 Console
NTSC games
If the Console is NTSC then it is not compatible with the broadcast standard for SA, and only NTSC games will work in it. All games in SA should be of a PAL I Standard, so they will not work in an NTSC Console.
Dec 25, 2006 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
