Question about GE JE2160 Microwave Oven
GE JE2160 light turns on when you open the door,but no display
Power kept going off/on. Had to keep resetting the clock.
  • 1 more comment
  • Anonymous Jan 11, 2009
    Light works,but nothing else does
    I'm the guy that had the message get cut off. Can't sign in for some reason.JE 2160 light works, but display won't.
  • William Miller
    William Miller May 11, 2010
    Sorry, but your subject line was too long and it got cut off. Can you reply back with your exact symptoms?
  • GE Master
  • 9,098 Answers
This is probably a problem on the control panel, which we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
But I'd like to first see the the
"mini-manual" (tech sheet) which should be hidden inside the unit behind the control panel or hidden on the left side behind the grille.
You can scan (at 300 dpi) at least the "schematic diagram" page and e-mail it to me at prototech@usa.net or you can fax it (in "detail" or super fine" mode) toll-free to 866-481-2802.
That way I first can see if anything else you can check might be the problem instead.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 12, 2009
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Display turn off and the buttons are not clickable
The owner's manual is here. Be sure you have the clock set correctly.
You can also try a hard reset by unplugging the oven for a couple of minutes, plugging it back in, resetting the clock, and trying again.
Sep 04, 2012 | GE Microwave Ovens
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
Hello Our oven (GE Microwave Oven JE2160) is not working, while the touch control panel light is on. I am sure the fuse inside the oven is blown. Can any one help me on: 1. The size of the screw driver /...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case, it may be a Torx15 or Allen style screw head, and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
Information on where to aquire a special fuse can be got from the manufacturers web site and browse for dealers.The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 18, 2010 | GE JE2160 Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    GE spacemaker Power goes off and clock needs resetting
    Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
    Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    I have a GE Microwave Oven model JE2160. The clock and time are 10 seconds fast per minute.
    The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    Otherwise, the manual may address some settings. You can download GE owner's manuals here.
    We're happy to help you and we'd appreciate your thoughtful rating of our answer.
    Jul 17, 2008 | GE Microwave Ovens
    Model JVM130G
    what brand is this and did the light go on when the door was opened before you changed the bulb?
    Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Light Stays ON Inside - GE JE2160
    It may be a stuck relay on or other problem on the control board.
    We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
    It's possible but not likely that you have a bad door swith or door switch mount.
    If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
    disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    Please write back with more details if you need further help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Nov 30, 2007 | GE JE2160 Microwave Oven
    Light Stays ON Inside - JE2160
    If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
    If not, then I would suspect a bad door switch or a problem on the control board.
    We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
    Please write back with your brand and model number if you need further help.
    Nov 29, 2007 | GE JE1540 Microwave Oven
    GE JE2160 Microwave Oven Logo
    79 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
