WE moved house, lost one of the four removable feet, now found ok, added new battery but the weight measure previously set is way out. please tell me how to re-set and obtain an instruction manual. Thanks.
SOURCE: I have lost my instructions
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
SOURCE: Everyone in my family can use my Salter electronic
I have same problem. I put it down to too much static electricity in my body.If i handle any battery powered gadget too long it goes wrong.
SOURCE: I have a Salter bathroom scales purchased about a
I would contact the Company that makes the scales and inform them of their defaulty scale that you paid your hard earned money and see what they say, They may replace it if you send them the defaulty one! Good luck.
