Question about Microtek SCANMAKER 4850 Flatbed Scanner
I need to know how to open the case
I am trying to clean the glass on a Microtek 4850. I need to know how to open the case. The Microtek support downloads do not contain the information for that chassis model. Note that I have opened the upper end, but cannot see how the lower end is connected. I have tried pushing the upper end off as well as gently prying the lower end. Both without success so far.
  • Anonymous Dec 28, 2007
    late reply, on the 5900 there are 2 small holes where the connectors plug in. the holes are small about 2 mm about half inch from the top and about 2 inches in. you need to poke a thick paper clip in here while using a screw driver to divide the lid and body, separate one side then the other.
    once you have both sides lifted, use some medium force and pull the mid
    section loose on both sides. (here is where i get stuck) i can't figure out the rest however there is now enough space to clean the glass from the inside.
    i used a car wax \ cleaner as a thin film of wax will keep dust from settling inside and the wax keeps smudges to a minimum. put everything back by
    applying pressure both sides to pop the top back onto the body.
    I do this every year or so... don't pull the lid too far apart... you should only get about 4 inches max and i blow the inside with can air before closing the scanner back up.
    hope it helps... if you figure out how to remove the whole lid...let me know.
    H.
  • Robert Blalum Jan 04, 2008
    Why would I want to open it up and clean it????? ......It gets dirty on the inside and this negatively affects the quality of the scan.
    Why else would I want to open it up?
Opening a Tevion(Microtek)3200: thanks for the paperclip tip! That gets us in. Then the straightened wire coat-hanger slipped through the front corners finishes the job. The clips are on the base this time, about 2.5 inches from the corners set in about half an inch from the joint. They hook into loops on the top panel and have to be levered the opposite way to the paper-clip ones, that is, towards the joint. The top still remains attached by the ribbon cable,I undid the 4 self-tappers affixing the front switch plate,also maybe as well to lock the mechanism before you start: turn the little orange screw underneath with a 20p piece or a dime or ten centimes (I'm sorry, I don't know the sterling /yuan exchange rate) ,Happy New Year, Redpath
Posted on Jan 04, 2008
    Genius:
  • 2,985 Answers
These things are made not to be opened. As they are sealed in manufacture I cannot see why you should want to clean the glass from the inside.
Posted on Jun 07, 2007
I need to clean the underside of the glass but don't know how to take the glass bed off.
if you are not an expert, you need caution to remove the glass for cleaning.
CAREFULNESS IS THE CODE
Nov 29, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
How to clean the underside of a microtek 9800xl
open it up...
you can try using a vacumm on the venting bars maybe it would help abit...
good luck
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Using my CD I was not able to program my Microtech 4850 to my com
I was weird how the original CD for this failed three times. So after a simple call I was given a website to go to and instructions on how to use it. In minutes it was up and running. Thank you for getting back to me and if you know someone who needs the same help the number I called was 310-687-5940. I went to support.microtek.com and used the download there to get my scanner back. Thanks again, Kelly
Jan 30, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
Driver for vista?
I don't know if this will answer you need but I called a number about my scanner and it seemed the person was very knowledgeable. The number is 310 687 5940 and I was refered to
Jan 04, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
No instalation cd 4850
I do not have the original disk to install my Microtek ScanMaker 4850. How can I install this disk now?
Jul 15, 2008 | Microtek SCANMAKER 4850 Flatbed Scanner
Microtek Scanmaker 4850 not compatible with XP
Hi.
You need to update your XP with the service pack 2, it's available on
http://www.microsoft.com/downloads/Browse.aspx?displaylang=en&productID=38DF6AB1-13D4-409C-966D-CBE61F040027
Note the star * requires validation of your installed windows
Feb 18, 2008 | Microsoft Windows XP Professional for PC
Microtek SCANMAKER 4850 Flatbed Scanner Logo
184 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
bigdaddyd2
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
