Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Samsung scx 4623-fh reset chip - Samsung SCX-4300 Monochrome Laser Multifunction Printer
  • 525 Answers
SOURCE: please help samsung scx
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!.
Posted on Jan 24, 2011
nakshatraipu
  • 241 Answers
SOURCE: how can reset scx 4623 torrer cartridge
Reset printer using reset software (permanent solution)
info@nakshatraworld.com
Posted on Sep 12, 2010
  • 24 Answers
SOURCE: how can I reset chip
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Posted on Nov 30, 2010
InfoGuy
SOURCE: how reset toner samsumg scx
Try this... http://www.tonerkits.com/ffix/ffix-samsung.html
It works!
Posted on Apr 15, 2011
SOURCE: i want to chip reset
i want to chip reset samsung scx 3201 model printer
Posted on Apr 24, 2011
What could be the solution of door open, close it on samsung scx 4623 w printer?
This is common. Check the right side of the front door. It will not be flush with the main case. Just give it a wack. it will work then.
Nov 28, 2015 | Samsung SCX 4623F - multifunction fax /...
My Samsung SCX-4623 F/X when and faxing has several. top to bottom lines
If you are getting lines on the faxes you send it means that the glass of the scanner is dirty. Best method to clean the glass is rubbing alcohol and a soft cloth. The alcohol will remove adhesives and white out better than glass cleaner. You may need to look closely because a small amount of adhesive will distort the scans and cause lines and may not be obvious unless inspected very carefully.
Jan 02, 2015 | Samsung Office Equipment & Supplies
I need a printer manual for the SCX 4623FW How and where can I download one.
this is a list of a lot of manual for your printer in the link below
http://www.samsung.com/us/support/downloads/SCX-4623FW
Jul 21, 2011 | Samsung Office Equipment & Supplies
Counter reset software for Samsung SCX-3201 Printer
CALL ME ALL THE SOFTWARE IS FREE FOR CHIP RESET 9352725376
Jan 06, 2011 | Samsung Office Equipment & Supplies
Samsung manuel for SCX-4623
Hi
Please click on the following link to get the manual
Manual for Samsung SCX 4623
I hope it works for you..
All the best!!
Regards
Dec 31, 2010 | Office Equipment & Supplies
How can reset scx 4623 torrer cartridge
Aug 23, 2010 | Samsung SCX 4600 multifunction Laser...
Dear Expert how to reset chip ML-2850 Series printer, please help me
If firmware update is unsuccessful, you can throw printer.
I recommend you build yourself a very simple "reset device" (resetter) for many models including this one. Address is,
http://www.tradebit.com/filedetail.php/178510406-at88sc0204-reset-software-full-package
List of chips that can be reset is,
Samsung ML-1630
Samsung ML-1631
Samsung ML-2850
Samsung ML-2851
Samsung ML-3050
Samsung ML-3051
Samsung ML-3470
Samsung ML-3471
Samsung ML-3472
Samsung ML-4050
Samsung ML-4550
Samsung ML-4551
Samsung SCX-4500
Samsung SCX-4501
Samsung SCX-4725
Samsung SCX-5330
Samsung SCX-5525
Samsung SCX-5530
Samsung CF-560
Samsung CF-565
Samsung SF-560
Samsung SF-565
Samsung CLP-350 (Bl/M/C/Y)
Samsung CLP-351 (Bl/M/C/Y)
Samsung CLP-610 (Bl/M/C/Y)
Samsung CLP-660 (Bl/M/C/Y)
Samsung CLX-6200 (Bl/M/C/Y)
Samsung CLX-6210 (Bl/M/C/Y)
Samsung CLX-6240 (Bl/M/C/Y)
...and many others.
Excuse my poor English.
Aug 20, 2010 | Samsung ML-2850 Series
How reset toner samsumg scx 4623 please
Aug 10, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
121 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
