Question about Acer Computers & Internet
No sound through external speakers
Replaced old CRT with Acer X223wbd on my Dell Dimension 3000 w/Windows XP system. Looks good but no sound through my external speakers. What could be the problem? Not a computer expert-
  • julierae Jan 11, 2009
    Thanks! I "misremembered" I had an add in sound card--one of the other inputs worked! Thanks so much!
  • 72 Answers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Posted on Jan 11, 2009
My dell dimension 3000 makes cracking sounds when i play music
Check your speakers first. Plug the cable from your speakers into a cell phone, ipod or some other music device that has headphone port. If the speakers are crackling then, then you know it's the speakers. If not, then it's a computer issue in which case you might want to contact Dell.
Mar 30, 2011 | Dell Dimension 3000 PC Desktop
Show me where the printer should connect to the back of dimension 3000 tower windows xp
google for dell dimension 3000 and you find the manuall see below i found it on :
External connectors:
9-pin connector; 16550C-compatible
25-hole connector (bidirectional)
15-hole connector
Network adapter
RJ45 connector
PS/2 (keyboard and mouse)
6-pin mini-DIN
two front-panel and four back-panel USB 2.0–compliant connectors
three connectors for line-in, line-out, and microphone; one front-panel connector for headphones
Mar 12, 2010 | Dell Computers & Internet
I a dimesion dell pc and did a system repair and now I recovered all my old data and now the sound will play I tried adding driver
System repair just rewrites the Operating System and registry causing software to act funny afterwards. I suggest since now you have access to your data back up all your data into a thumb drive, cd ,dvd or external hard drive. Reinstall Operating System(windows xp). .here is a site to show how to do it
hope that helps
Feb 28, 2010 | Dell Dimension 3000 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
I have an Dell Dimension E510 running windows XP. I have 5.1 surround sound speakers that were working fine until recently. Only 2 speakers work; left and right. None of the others have sound. I have...
Reinstall the software for the sound system, this should redetect the speakers properly as 5.1 surround sound speakers.
If you do this and it still doesn't work then the speakers are bad and your sound system would need to be replaced.
Dec 01, 2009 | Dell Dimension E510 PC Desktop
I have a dell dimension 3000 and i can't get any audio sound. it came with a samsung sw-2525 CD/RW . come to think of it i don't get any sound through the external speakers. it has no internal...
check to see the sound is working under the control panel .. system icon click and goto device manager
you might have a bad driver for the sound device or the device is bad on the motherboard
also test under sound devices.. and set the default device to use ..
Sep 28, 2009 | Dell Dimension 3000 PC Desktop
No sound upon installing E-MU 0404 pci card and driver
Hey ya'll.
I had the same problem with everything installed,icons on the screen etc...I took my stuff to my computer wizard and he came with the following solution which is:
Make sure that you have a Windows XP "SP2 or GREATER" this is the kicker.Go to the requirements sheet if you need more info.
Anyway I did that upgrade from SP1 to SP2 and it works like a charm with pristine sound.
Good luck fellows.
monsieur M.
Mar 18, 2009 | E-Mu 0404 Sound Card
No Audio Device
hmm strange.. sounds like plug n play service issue or a bad xp install. with dells usualy u have to install 1st desktop system software then chipset then audio, video, ethernet.
Oct 05, 2008 | Dell Dimension 3000 PC Desktop
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
244 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
