Question about Samsung TV CS29Z40
Vertical ic for samsung tv cs 29 z40 - Samsung TV CS29Z40
2 Suggested Answers
gopakumarg43
  • 75304 Answers
SOURCE: Which remote control used for 29" TV CS-29L30ML
If there is any customer sevice center of Samsung nearby, please enquire there about the remote model of your tv set by giving your TVs model number, usually marked on the back side of the tv. They can surely guide you.
Posted on Oct 15, 2010
What is samsung vertical ic for 29''
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 05, 2014 | Samsung Televison & Video
My Mitsubishi CS-2610 S-Monitor suddenly blacked out! I am having a difficult time finding a job, and cannot replace my TV right away. Can it be fixed?
tried to re soldered first cold soldered component parts at the main board which may get loose contact. if can not get with re soldered check bulged or leak capacitor at the vertical section. and then try to observed if the vertical ic is too hot, that was mean the ic get bad.just replaced with new one and re check other component near the ic.
Aug 09, 2012 | Mitsubishi CS-26201 TV
When I put on my Samsung Plano TV (Model is CS-20M16ML) the picture display after sometime becomes problematic. The blankness appears at the bottom of the screen and then gradually goes up and up thus...
Vertical output IC has the fault. Try this site named "Electro-help". You might get details from here. Type this name in google search box and click enter.
May 01, 2012 | Samsung WS32Z308P 32" TV
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Which remote control used for 29" TV CS-29L30ML SAMSUNG
Oct 15, 2010 | Samsung CW29M64NS 29" TV
Horizontal line across my tv
This is a problem with the vertical circuit and is relatively common. If you can solder you can fix this yourself. First try resoldering the pins on the vertical IC. If that fails to resolve the problem, replace the IC. This IC is a small flat IC attached to a heatsink having about 11 pins or so. Is will be marked LA7837 or something similar. Post the marking here and I'll confirm the part.
Keep us posted.
Dan
Aug 19, 2008 | Mitsubishi CS-26201 TV
Mitsubishi cs 35203
That sounds like vertical failure. Does the blue line run across the screen from side to side? Try resoldering the vertical output IC and see if that straightens it out. This is sometimes been a problem with that chassis. Let me know how you make out or if you need additional help.
Mar 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Samsung TV CS29Z40 Logo
Jerry Greenberg
Jerry Greenberg
