Question about Motorola TalkAbout T5000 2-Way Radio
Motorola t5000 If the eliminator code is set to 0 both radios receive the transmission. Once we set the radios to any eliminator code only one receives transmissions - have double checked that both are on same channel and same eliminator code, etc.. have tried various combinations of codes and channels Thanks
  • mark celedonia Jun 10, 2007
    Have checked - QT not on either radio - its off
    Still only one will transmit and receive when the eliminator codes are set to anything but 0 the second radio doesn't receive any communication - can transmit on it though!
    Thanks - I'll just keep it set to 0
  • mark celedonia Jun 11, 2007
    I'll explain this as best I can!
    Radio A set to eliminatior code 1 transmits to radio B set to 0 but Radio B(0)doesn't transmit to Radio A(1)
    Radio A set ot 0 doesn't transmit to Radio B set to 1 but Radio B (1) transmits to Radio A(0)
  • 123 Answers
If you have already checked both radios have the same code and channel both radios must reicive and transmit between each other check if you have any QT in any display this is a third condition to reicive.
Posted on Jun 07, 2007
  • Ernesto  Garcia
    Ernesto Garcia Jun 11, 2007
    I think One of the radios has problems with the encode/decode circuitry, try to set one of them with code 1 and the other with code 0 then switch between them.
    This could tells you wich one is not sending code.
    Or maybe one of them is sending wrong code, you will need a thrird radio to test wich one is it
  • Ernesto  Garcia
    I think one of the radios has problems , and encodes/decodes diferent code that shows on display
    try to get another radio to find out wich one of this two radios has the problem
How do I get the Motorola T5000 and Boafeng UV-8D radios to communicate with each other?
check you settings in the radio,follow your instruction manual for the radio
Jun 11, 2015 | Motorola TalkAbout T5000 2-Way Radio
Motorola Talkabout t5000 sold at Costco (several years ago) with a mini T4500. An insert was included so the mini could talk to the others. It says to hold the menu button down and then select 0 for the...
Your frequency and your code are two separate settings. When you walk your way through the menu the frequency choice will come before the code choices. Frequencies will count from 1-14 or 1-22. Codes (aka interference eliminator) will have may more choices and one of them will be Zero. It appears from looking at the T4500 manual that it does not offer "code". So on this one the code is already "zero" (off). On your T5000 you should be able to navigate to the CODE using the menu button, then use your plus or minus button to get you to "zero", then press the PTT button to save your choice.
Best regards.
Our first thought when reading your dilemma is to check the Menu Lock. Holding the Menu button in for 3 seconds will lock/unlock your buttons. You should have an icon depicting a lock displayed on the screen.
Aug 17, 2013 | Motorola T5000 Two Pack 2-Way Radios with...
I need to reset my motorola T5000 how do i do that?
Couldn't find the user guide for the T5000, but did find the T4900 and the T5100. You might try looking in them to see how to restore your settings. Not all TalkAbout radios seem to have a quick reset function. You may need to restore the unit by taking it back to a basic mode. Shut off special features such as your Interference Eliminator Code, VOX, Qt filter, Call Alerts, etc.
Here is a link to the T5100 user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Here is a link to the T4900 user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4800_UserGuide.pdf
Best regards.
Mar 08, 2013 | Motorola TalkAbout T5000 2-Way Radio
Cannot receive or transmit
A few items to check:
Be certain both radios are set to the same:
Frequency
Qt filter
For a simple test set the Code, Qt filter, and any other special features to off or zero. This will allow you to find out if the radios will work simply on their frequency. Once you establish this, you can add in the features as you need them.
Here is a link to the T4900 & T5100 user guides (couldn't find T5000 alone.):
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXx_User_Manual_E.pdf
Best regards.
Jun 26, 2012 | Motorola TalkAbout T5000 2-Way Radio
I have 2 Motorola T5000s and 1 T4500 that came together in a set years ago. The two T5000s seem to connect to each other fine, and the T4500 receives messages and signals from the T5000, but does not seem...
Here's a link to the user guides:
http://www.giantintl.com/ContentManage/manuals/Moto/T4500_User_Manual_E.pdf
Check your interference eliminator code (aka PL, private line, or code). It is likely set to zero (off) on the T5000s and set to a different number on the T4500s. They must match to work together. Otherwise the one with code turned on will not recognize the other one.
Best regards.
Jan 27, 2011 | Motorola Talkabout T4500 (7 Channels)...
How to get them on the same channel?
Can't find a straight T5000 user guide, but did have a link to the T5100 and T5200 series http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
This should help you with programming your T5000 radios to match one another. Be certain the frequency and interference eliminator code match identically. If it has a Qt filter, set it to zero (off), for basic operation.
Best regards.
Dec 25, 2010 | Motorola TalkAbout T5000 2-Way Radio
Rx not working
You need to check the programming of your Frequency, interference Code eliminator and Qt filter, if any. All must match one another for the radios to communicate. You have posted under the T5000 heading, here is a link to the nearest numbered user guide. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
Best regards.
Nov 30, 2009 | Motorola T5000 Two Pack 2-Way Radios with...
Cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
Aug 07, 2009 | Motorola TalkAbout T5000 2-Way Radio
I can rx transmissions but they can't hear me.
Check the settings of both your interference code eliminator and your Qt filter (if your model has one). These codes need to match the other radios exactly. If the other radios have a Qt filter and your unit does not, then the Qt filter would need to be shut off on the other units.
Feb 11, 2009 | Motorola TalkAbout T5000 2-Way Radio
Motorola T5000 Rx problem
Hi SirDrag,
Your concern could be the internal speaker of the T5000. This could be verified by attaching an external speaker or a headset compatible with the unit through its accessory jack. Should this be the case, it of course would require replacement. Though Motorola speaker for this model is proprietary in design, those made for Alinco, Icom, Kenwood and/or Yaesu should also work. The only concern would be getting one that will fit the physical mounting limitations of the front cover.
In some instances, it could be the volume control developing blind spots along its carbon pad. A spray from an electronic contact cleaner should do the job (albeit temporary).
It is also possible that the Interference Eliminator Code setting is different with that of the TX radio.
Worst case possibility is a defective electronic component (such as the op amp) which would then require the professional services of a qualified communications technician.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola TalkAbout T5000 2-Way Radio Logo
311 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
