Question about Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive
UltraMax Plus won't mount red lights flashing
HDD connected by Firewire 800 to iMac. Has worked OK for a year now it fails to mount and the 2 red HDD lights flash alternately. Disc Utility doesn't see this drive. Tried connecting with USB 2, no change. Hope somebody can help. Thanks all.
3 Suggested Answers
  • 97 Answers
SOURCE: Can't mount my external Iomega harddisk anymore
Try running disk utility. If it can see the hard disk but it isn't mounting it, try clicking "repair" or if that is greyed out, "verify" then "repair". Be warned that this could take a very long time, so leave it over night. It may even look like it has crashed. This may either fix the problem, or tell you that the drive can't be repaired (in the data sense) and it will hopefully mount it read-only so you can retrieve the data. You will need another drive with enough space to copy everything off. If copying data fails, try copying folder by folder or even file by file to get off all files that are ok, as otherwise it will just give up when it finds corrupt data.
If disk utility cannot see the hard disk at all, try the other interfaces (usb/firewire/sata). If it can't see it in any of them, try it on another computer. If none of them can read it then the unit is dead. You may be able to retrieve your data by taking the unit apart, removing the hard disk, and placing it in another enclosure. This will probably void your guarantee though, so it's a choice you may have to make :(
Posted on Oct 27, 2009
SOURCE: iMac failing to recognize Iomega UltraMax Hard Drive
I have the same problem too, this iomega is terrible, I have it only less than two months and it is not working already. Evan it has one year warranty I will not suggest anyone to buy it in the future.
Posted on Feb 28, 2010
Xbox 360 won't delete anything, plus it won't format
You can try connecting the HDD to a computer and formatting that way. FAT32 if all else fails will need replaced. Sounds like HDD has problem.
Mar 09, 2013 | Microsoft Xbox 360 Console
Where can one buy a replacement pcb control board for a iomega 'ultramax plus' unit? My existing one has a damaged IC component at 'U4'....and possibly more elsewhere on the board.
No one sells what you're looking for. I'm assuming the drives were in a raid configuration which means you can't put them in an enclosure to get the data off. Your best bet is to purchase another unit and replace the drives. This thing is hella expensive. If you don't need the data you can get a different one bigger and cheaper. http://www.sears.com/iomega-33991-esata-firewire-800-firewire-400-usb-2.0-500gb/p-00389575000P
Oct 16, 2012 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
Iomega Ultramax red light turns on at start.
It's probably the power supply. Iomega has been having lots of power cord failures. I had same problems and thought it was the drives until I did a internet search and saw lots of people having the same trouble. I called Iomega and they sent me a new cord. Problem fixed. It's the little black box that dies...
Apr 04, 2012 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Hdd i/o firewire port won't work when connected with my hp probook laptop. do i have to install some drivers or firmware. when i use just hdd, things are just fine, evrything works fine. i need...
You cannot use the drive without external power, specially with the 4-pin firewire: there are some USB models that allow it (usually 2,5" drives), but you need 2 USB outlet oth the PC (one for the data and power, the second for power supply). About the compatibility you shouldn't have problems.
Aug 07, 2011 | Focus Enhancement FSHDD-1 (ASYF070701) 40...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
IMac failing to recognize Iomega UltraMax Hard Drive
Jan 03, 2010 | Iomega 33089 250 GB Hard Drive
I've been using two of these drives for a few years.last week one of them stopped connecting to my iMac (10.6.1). Today the second one did the same. I turn on, get a white light, hear clicking in the...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Oct 03, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive Logo
76 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
