Question about Tablets & eReaders
How do i unbrick my ainol tornado 7" tablet
When not USB plugged into my PC my Ainol Nova Tornado 7" tablet will not get past the unlock screen. When USB plugged to my PC it takes me to the USB plugged in screen and when I press the Home button on the side of the tablet it takes me to the home page displaying all my apps, but will not let me get past to begin using it.
nliwilson
  • 114 Answers
SOURCE: Mobits A221 tablet pc reset
You can forcibly power off the unit in exactly the same way you can any PC, hold down the power (on/off) button for 6 seconds.
Technically it's actually 4 seconds but 6 seconds gives you a margin of error. Unfortunately Microsoft make poor quality products and Windows XP Tablet Edition is no exception, Keep a a note of this procedure as this won't be the last time you need it.
Posted on Dec 04, 2007
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
benwabnick
  • 2404 Answers
SOURCE: I cannot rotate the screen's display using the tablet control button
Try holding down the CTRL, ALT and the up arrow or any of the arrows and see if that does the trick with rotating the screen.
As far as the normal rotate button is concerned, try downloading the drivers for it thru toshibas website. If you have the model number of your laptop I can help you with that.
Posted on May 21, 2009
SOURCE: pen not detected on especific zones of display
Had the same problem. Just open the tablets screen enclosure. Look at the back of the LCD panel. You will see a little circuit board with several black plastic connectors. Push all these connectors firmly to the PCD. You will notice that one or more have come a bit loose. Before closing the lcd panel housing, put some adhesive tape over the connectors. This will prevent them from failing again.
Posted on Sep 06, 2010
misterwhiz
  • 32 Answers
SOURCE: Why won't my tablet let me logout of facebook?
Go to settings, applications, then find Facebook, click it, and click Stop or Close. That'll take care of it!
Posted on Jul 20, 2011
Can I charge my Novos 7inch tablet through a usb cable attached to my computer there seems to be a problem charging through normal port
There are only so many milliamperes available to the whole USB bus on any computer. Having too many devices connected will cause not enough power to charge your tablet.
Try a wall adapter.
Mar 02, 2015 | Ainol Novo 7 Fire Android Tablet
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
Feb 23, 2014 | Android Ainol Novo 7 Paladin Tablet PC
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Dec 06, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
Jan 22, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Ainol Novo 10 Hero Tablet won't turn on
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Dec 26, 2012 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Tablets & eReaders Logo
110 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
