Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110 48182791 type 113-01
Will not drain after wash cycle
jsrock516
  • 5911 Answers
SOURCE: kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 17, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
Hi, My kenmore front loader washer (C44072) doesn't drain after the wash cycle. The drain pipe is straight and full of water. I have noticed this problem earlier. Before I was able to force the drain by...
check for a kink drain hose are you have lint clog up in you pump ,you have to take the lower front panel off to see the pump depend on your model.you may have the pump in back of your washer.
Apr 25, 2010 | Kenmore 43142 Front Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer model #23832100. It will
Yes....the lid switch is broken...will need to be replaced.
Jun 10, 2009 | Kenmore 22422 Top Load Washer
Washer stays in cycle and doesnt advance to additional cycle
Hi, It sounds like you timer has gone bad. Would need more of the model # ro be sure on what type timer you have.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Kenmore 22622 Top Load Washer
Kenmore 70 series Washer will not go to spin cycle
Check the lid switch. That is a VERY common problem on these models.
Dec 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
101 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
