Question about Quantum DLT 8000 DLT Tape Drive
Quantum 8000 dlt tape drive all left side lights blink
3 Suggested Answers
  • 362 Answers
SOURCE: DLT-S4 tape is stuck in Quantum drive all 3 LEDs
Hello, on some of the older DLT drives, if you press the 'eject' button several times the drive firmware attempts an unload operation. I'm not sure of the number of times you have to press it though...try pressing it in and releasing it 3 times (in quick succession). If that doesn't do anything, try 7 times.
It's worth a try!
Regards
nicam49
Posted on Nov 01, 2010
  • 362 Answers
SOURCE: How do you manualy eject a stuck tape from a
Hello, if it has an eject button, press it quickly several times (can't remember the exact number; try 3 first, then 5, then 7)the reason being that on earlier DLT's the firmware would cause a drive reset which would, if there wasn't a detached leader or other physical problem, result in a tape unload.
p.s. do let me know how you get on!
Regards,
nicam49
Posted on Dec 08, 2010
I need manuels for the Quantum L700, I need to test unit.
Manuals, drivers and diagnostic software is available here;
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/DLT7000/Index.aspx
Feb 02, 2011 | Quantum DLT 7000 AUTOLOADER (l500) DLT...
How do you manualy eject a stuck tape from a Quantum DLT VS80 external tape drive
Regards,
nicam49
Dec 08, 2010 | Quantum DLT VS80 DLT Tape Drive
DLT-S4 tape is stuck in Quantum drive all 3 LEDs flashing together. Eject tape button does not work, how to get the tape out?
It's worth a try!
Regards
nicam49
Nov 01, 2010 | Quantum DLT-S4 DLT Tape Drive
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
Dlt-v4, the drive accepts the tape only to spit it out
You have to try the other tape if the same problem you have to replace the head.
Feb 05, 2010 | Quantum DLT-V4 DLT Tape Drive
What can cause a 2680 Error code on a Quantum M1500 tape system?
Drive 1 has reported a hardware error, Check with your drive 1 is it blinking with any amber led.
Dec 15, 2009 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
Not backing up
Run Quantum's DLT from the following link:
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/Sage/Index.aspx
Understand that a bad tape will produce failed tests, so try to use a "known good" tape.
Regardless of the Pass/Fail results, the LogPages are as important, as they capture past failures and may point to the real problem.
Dec 08, 2009 | Quantum DLT-V4 DLT Tape Drive
Dlt tape drive left lights blinking, internal fault
This is a hardware fault with the drive (Quite common) The drive needs to be properly repaired (Main PCB Fault)
Send it to www.tape-drive-repair.com as they are quite good at this sort of thing and are not expensive
Mar 02, 2009 | Quantum DLT 4000 DLT Tape Drive
I accidentally closed the window
Unfortunately no but i sent you a message via the comment. Go to My profile then chats then view session to see my comment. I gave you my contact information and then ill have you contact me.
Nov 09, 2008 | Quantum DLT 8000 DLT Tape Drive
Tape drive replacement trouble
drivers are a simple solution..here's a link for printer drivers, which you can jump through to find tape drivers, with the dell model number.
Mar 10, 2008 | Quantum DLT VS80 DLT Tape Drive
Open Questions:
Quantum DLT8000 Drivers not installing properly Something strange going on with the installation of the drivers on my DLT8000. I'm able to use the xTalk program to run tests and stuff on the tape drive from windows so I know it's working properly. However, this is what the device manager says: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) and it shows the little red exclamation point. Getting to this spot was difficult because of some issue with the INF file which (I guess) I was able to fix via this blog post: http://www.loosewireblog.com/2006/07/how_to_fix_a_br.html I added the [ClassInstall32] to the very end of the INF file that came with the downloaded drivers from the Quantum website. I was able to determine that the key name for this type of device is: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318} and sure enough, there is a subkey 0000 which contains all the info about my tape drive. This is what my setupapi.log file is showing: #-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{A270A48C-25F4-4B08-8975-00D9D0356FF2} #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device. #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device. #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #I022 Found "SCSI\SequentialQUANTUM_DLT8000_________" in c:\documents and settings\mike\desktop\dltdriver\QntmDlt.inf; Device: "Quantum DLT8000 Tape Drive"; Driver: "Quantum DLT8000 Tape Drive"; Provider: "Quantum Corporation"; Mfg: "Quantum"; Section name: "qntmdrv_Inst". #I087 Driver node not trusted, rank changed from 0x00000001 to 0x00008001. #I023 Actual install section: [qntmdrv_Inst.NTx86]. Rank: 0x00008001. Effective driver date: 10/19/2006. #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #I063 Selected driver installs from section [qntmdrv_Inst] in "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I320 Class GUID of device remains: {6D807884-7D21-11CF-801C-08002BE10318}. #I060 Set selected driver. #I058 Selected best compatible driver. #-124 Doing copy-only install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E366 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn, user said ok). Error 0x800b0100: No signature was present in the subject. #W187 Install failed, attempting to restore original files. #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-024 Copying file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" to "C:\WINDOWS\system32\DRIVERS\QDLTx32.sys". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-166 Device install function: DIF_REGISTER_COINSTALLERS. #I056 Coinstallers registered. #-166 Device install function: DIF_INSTALLINTERFACES. #-011 Installing section [qntmdrv_Inst.NTx86.Interfaces] from "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I054 Interfaces installed. #-166 Device install function: DIF_INSTALLDEVICE. #I123 Doing full install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #I163 Device not started: Device has problem: 0x27: CM_PROB_DRIVER_FAILED_LOAD. #I121 Device install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030" finished successfully. That #I163 error is probably what the problem is but I don't know what to do now... Any help is greatly appreciated.
Quantum DLT 8000 DLT Tape Drive Logo
Top Quantum Computers & Internet Experts
SirEbrum
terminalcon
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
