Question about Samsung AW0503B Air Conditioner
Samsung silver nano leaking water inside
Samsung Silver nano model number SH24ZP68 is dripping water onto carpet inside when the unit is on cool air
2 Suggested Answers
  • 415 Answers
SOURCE: I have a samsung silver nano...the indoor unit
  • Ensure Air Filter is clean - clean as necessary
  • Ensure Evaporator coil is clean - clean as necessary
  • Ensure Condensor coil is clean - clean as necessary
  • Inspect all wiring inside the unit for any loose or damaged connections - correct as necessary
There could be a failed compressor relay, run capacitor, or compressor motor/valves. Of course, it could also have lost it's refrigerant charge.
Without being onsite with toolbox in hand, I hope you find this information to be very helpful moving forward. :-)
Posted on May 10, 2010
Water leaking from right side of Altima its not air condition water pump its dripping off a silver thing behind the wheelcould it be my
Could be just your windshield fluid container leaking,which you should not worry about,check container and see if it is low and put a mark on level and see if it goes below,Your pump is connected to container and it may be leaking there,look and see.
May 03, 2013 | 2006 Nissan Altima 2.5
Hi there Please help , not sure if the aircon needs to be re-gassed , bought a place with the aircon - a samsung silver nano . the aircon has been working fine but lately it seems that we only have...
I believe you're on the right track. The coolant gas may be low or absent all together. Having it professionally serviced will determine if that's the problem and also determine if their is a leak in the coolant system. Or it may simply be the control knob that's used to set the cooling function is not working.
Feb 15, 2011 | Samsung Heating & Cooling
Our Jenn-Air refridgerator is 11 years old and is leaking from the back onto the floor. We looked in the back behind the cardboard panel and saw that the pipes around the( pump ?)located in the lower...
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 11, 2010 | Jenn-Air Refrigerators
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
I have a samsung silver nano...the indoor unit & the outdoor unit fans are running...but there is absolutely no cooling. Any idea why?
May 10, 2010 | Samsung AW0503B Air Conditioner
Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Aug 19, 2009 | Heating & Cooling
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
Air conditioner leaking
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Sep 19, 2007 | Sharp AF-S120FX Air Conditioner
Samsung AW0503B Air Conditioner Logo
81 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
