Element Electronics HD LCD TV ELDFT404-B Logo
A
Anonymous Posted on Nov 29, 2012
Eldft406 HD Digital LCD TV.Just got it and the sound goes in and out.
  • Anonymous Jan 05, 2013
    I was able to find the website and I wanted to register my tv but guess what? the model ELDFT406 doesn't even exist in their options. I bought the TV brand new from Target and the sound goes in and out at ramdon chanels, I have to turn off my TV and turn on every time if I want sound...totally sucks. For a moment I thought it was my satellite but it isn't. Don't know what to do.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
467
Points
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1156
Points
I have this same one and it shuts itself off at random, one time after only being on for 40 minutes. It started within 2 days of it being set up and it was maybe used for 6 hours total when it first shut off. The remote hardly works too. Other people have the same problems with this TV, read the reviews of it on Target\'s site. I got mine at Target so I have 90 days to return it and I\'m waiting until around the beginning of Feb. when HDTVs go on sale again. I suggest you just return it,. You can\'t even find it on the manufacturer\'s website.
1 Related Answer
Anonymous
  • 4889 Answers
  • Posted on Jul 23, 2011
SOURCE: Element Electronics 32" FULL HD
What exactly do you mean by goes silent? Does the screen turn off but you can still hear the audio? Please provide this info so that I can help you with your problem.
Turns off
Main board fault. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Eldft406 tv is popping and no sound is coming out.
What is popping? Do you hear popping from the speakers or the back of the TV? You could have a serious issue on the power supply of the TV making this sound. Below is a link to the power supply for that TV.
http://www.tristatemodule.com/p-26991-lk-pi400112z-westinghouse-tv-module-power-supply-cqc04001011196-eldft406-cw40t2rw.aspx
There are no audio outputs on my 37 lcd only four audio inputs. How do I connect my surround sound system.
look for an optical or "coax" digital audio connect jack. That will transmit all surround sound channels on a single cable. That will go from your TV to your surround sound "receiver's 'digital audio in'
Also - if you are using HDMI the sounds goes over that cable along with the video.
I tried to register my new Element Electonics 40" Model - ELDFT406. Says model # doesn't exist ? Also having trouble getting the tint setting.
so you shouldn\'t bother too much with it. I have the same model and it shuts itself off whenever it chooses to. I\'ve only had it since the 23rd of November, and it shut itself off after 2 days and maybe being on only 6 hours in those two days. It shut off the other day after 40 minutes. Read the reviews on Target\'s site, most people have issues.
On Facebook, the manufacturer said they would be adding this model to their site within a week, and that was around the 26th of November that they said that and it\'s still not on their site yet. I got mine at Target and I have 90 days to return it, so I\'m going to wait until TVs go on sale around the beginning of Feb and return it.
1helpful
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
How to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy...
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
1helpful
Have a Magnavox 37 inch lcd hd tv When I turn the power on the green light flashes for about 10 minutes or so then goes solid. Once it is solid it turns off Turn it back on its solid again then off it goes...
sounds like the audio / digital board is going bad ---- they are about 130 refurbished and 300 new ----- look for one online before you pay an overpriced service tech who really doesnt know how to fix these tv's ----
I called the service support and they gave me three companies in Nevada --- each one of them had no idea what the codes meant, but would look at the TV for 225.00 - sounds like they need new companies to do their repairs on warranty
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
